Author Topic: Squeaker.  (Read 1577 times)
YoungFluff03TJ
Squeaker.
« on: July 22, 2011, 01:24:19 PM »
My TJ squeaks and I dont know what it is. As far as I can tell its some suspension issue, as it occurs all the time. Jeep dosnt even have to be running let alone moving, but when I rock it side to side squeak squeak squeak and when i go over bumps squeak squeek squeak. Very annoying. Does anyone have any suggestions/ experience with something like this? I jump under there and I cannot tell where its coming from....it seems like its coming from the coils but I dont see how.. ANY way. any help is appreciated.
03 TJ sport. 3" BDS <2yr old 33's
Offline Jrama
Re: Squeaker.
« Reply #1 on: July 22, 2011, 02:48:24 PM »
I'd say if you don't flex the suspension enough, it becomes stiff and squeaky. My recommendation: wheel the crap out of it
I've been doing a regular schedule of wheelin with mine and its real quiet ;D
Offline Bone206
Re: Squeaker.
« Reply #2 on: July 22, 2011, 04:18:28 PM »
if your shocks have rubber shock mounts or grommets, that'd be my guess. Try moving them or squirting some oil on the grommets and see if it goes away.
Re: Squeaker.
« Reply #3 on: July 22, 2011, 04:52:48 PM »
My sway bar end links squeak all the time. Got sick an tired of replacing them every 2 months when the new ones started to squeak so I just let them make all the noise they want. Thanks RE. Love those squeaky endlinks...
Re: Squeaker.
« Reply #4 on: July 22, 2011, 06:29:27 PM »
Rubber bushing needs some white lithium grease. Which one? Your guess is as good as mine. Put it on a jack and start wiggling.
Offline binare
Re: Squeaker.
« Reply #5 on: July 25, 2011, 07:03:20 PM »
X2 undo em next time your wheeling and see if its stops. If it does replace em over and over again or learn to love the squeak.
YoungFluff03TJ
Re: Squeaker.
« Reply #6 on: July 26, 2011, 12:28:49 PM »
ah pretty sure its those endlink discos. thanks for the tips guys
