Author Topic: axel swap  (Read 1532 times)
Offline giorno71
axel swap
« on: July 27, 2011, 10:13:13 AM »
just woundering if anyone has put a xj front axel in a yj and if its a good swap? I have a 94 yj and a 93 xj, the xj is not road worthy and needs to much to fix, i tried the search function but didnt find what i was looking for.
        thanks.
Re: axel swap
« Reply #1 on: July 27, 2011, 11:14:00 AM »
no its not. YJ is leaf sprung XJ is coil sprung. you'd need to cut off the perches/etc on the xj axle and then buy spring perches and reweld them on, buy new ubolts etc.
infact the parts needed just to swap it would cost more than you can find a junkyard YJ D30 for.......
Offline giorno71
Re: axel swap
« Reply #2 on: July 27, 2011, 12:40:23 PM »
well i was kinda looking at swaping the front axels to have coil springs on the yj snd get rid of the leaf springs. i know id have to fab up control arms and that kinda thing. sorry guess i should of explained my plan better
« Last Edit: July 27, 2011, 12:51:51 PM by giorno71 »
Offline Black Betty
Re: axel swap
« Reply #3 on: July 27, 2011, 03:08:15 PM »
If you are going to that trouble, don't put a d30 in there, go with a d44 or 60 etc.
Stupid hurts
Offline giorno71
Re: axel swap
« Reply #4 on: August 09, 2011, 03:31:34 PM »
im quite happy with the dana 30 i,v owned my yj 14 years now and never gave me one problem even the shift fork vacume is stock and i have the cherokee for parts so thats one thing i dont have to buy, why buy when i already have??? i dont mind the ideas but i,m justwondering if anyone did what im asking?
Re: axel swap
« Reply #5 on: August 09, 2011, 03:56:27 PM »
Tons of people have converted a YJ to coil / link suspension but if they are going to that extent it is usually with one ton axles and coilovers.  Search Pirate, there is tons of info there
Re: axel swap
« Reply #6 on: August 09, 2011, 05:44:10 PM »
if you havent had any issues with your yj for 14 years then why change the suspension. cut the xj brackets off the dana 30 and mount leaf spring pads. its a little bit of work as compared to a lot of work to doing the coil conversion. just a thought. i hope the xj dana 30 is high pinion. if not then not much point swapping anything. or, look for a later xj hp d30 with the larger u joints. then you'll have a much better upgrade over the stock d30.
theres a lot of info out there for this sort of thing, check jeepforum.com or pirate4x4.com
good luck
Offline Greg-100
Re: axel swap
« Reply #7 on: August 20, 2011, 11:03:30 AM »
While on the topic....
Can you swap the gears and the inner and outer shafts from the XJ to the YJ housing?
(both D30/D35)
(I have some issues with ratios and two piece passenger shaft on my YJ)
Greg
Re: axel swap
« Reply #8 on: August 20, 2011, 12:12:28 PM »
(both D30/D35)
Greg
As long as both diffs are high pinion D30s there are no issues.  No issues with the D35.  However, there is a carrier break for both diffs, one is 3.54 and up, and the other is 3.73 and up I believe.  I don't remember which one is which
As for the shafts, the shafts will swap over no problem, but you need to install a new passenger side axle seal
