Author Topic: Blower resistors  (Read 1100 times)
Offline Knox
Blower resistors
« on: August 10, 2011, 07:19:53 AM »
Anyone have regular problems with the resister or contacts melting?
I lost my first 2 fan speeds and have started a little bit of reading.
http://www.jpmagazine.com/techarticles/electrical/154_0710_jeep_fire_prevention/index.html
http://www.jeepforum.com/forum/f9/2002-blower-resistor-pics-520800/
Just wondering if this will be a common occurrence and if I should go ahead with the relay fix or just replace the resistor and hope it doesn't happen again
2003 TJ
Offline 01sahara
Re: Blower resistors
« Reply #1 on: August 10, 2011, 09:37:18 AM »
Happens every year in the TJ
Offline rws
  • Stump Grinder
« Reply #2 on: August 10, 2011, 08:11:22 PM »
Just replace the resistor.  They wear out on most (or some) older vehicles.  If it burns up every six months start looking for the cause.
« Reply #3 on: August 10, 2011, 09:21:44 PM »
Resistor packs that continuously burn out are often a sign that the blower motor is going. As the blower motor wears out it often starts pulling more and more amps.
Offline egklassen
« Reply #4 on: August 10, 2011, 10:02:46 PM »
I don't know if I have the same problem but, my "original" blower switch went nuclear I picked up one off Ebay. It lasted about a year. So I built my own out of 3 push type on/off switches and haven't had a problem since
