Author Topic: New tire carrier on  (Read 2135 times)
Offline Delco21
New tire carrier on
« on: August 15, 2011, 07:33:19 PM »
Finally got my spare mounted behind the commander like I wanted
Next I wanna figure out how to mount a highlift jack and a jerry can
Zombie outbreak response unit
Re: New tire carrier on
« Reply #1 on: August 15, 2011, 07:39:35 PM »
im guessing its just a pin and then you can lower it to open rear hatch .. if so cool do you have any problems with it moving side to side when your driving
Offline Delco21
« Reply #2 on: August 15, 2011, 07:41:19 PM »
A very little bit but im working on a way to rectify it just not sure what yet
Its definately not enough wobble to bother me yet
« Reply #3 on: August 16, 2011, 10:31:32 AM »
i would never mount a hi lift outside. Dual gas cans would look sweet.
Offline Evil-Jeep
« Reply #4 on: August 16, 2011, 12:45:10 PM »
x2, I mounted my hihglift on the front bumper, it usually needs to be "convinced" to work properly most days. It was a better option than mounting inside with 2 kids though.
« Reply #5 on: August 16, 2011, 12:58:16 PM »
You can buy a neoprene boot from Hi-Lift that slips over the ratcheting mechanism for $35 . Protects from rain, snow etc. Princess Auto has them.  You can also buy a rubber isolator so the handle doesn't rattle while you drive, and locks with mounts can be purchased so thieves don't walk away with it. I usually lubricate mine once a month. I've owned the same Hi-Lift for 15 years and it's seen duty on 5 different vehicles mounted outside.
« Reply #6 on: August 16, 2011, 01:33:00 PM »
i did not know that. good info.
Offline Elsifer
« Reply #7 on: August 21, 2011, 08:41:17 PM »
Pound some shims into the receiver to keep the sidey-sidey motion to a minimum. But not a perfect solution.
Drop bumper, build rear internal frame, notch/cut plastic bumper ton accept tire+jerry holder. Frees up stock receiver for recovery/towing.
Get rid of that strap or you'll smash that rear window. Drill hole thru bottom, use receiver bolt lock to secure fronty-backy motion. Would likely save back glass from smashy-smashy in a fender-bender.
VA6CPL
Jeepless....
« Reply #8 on: August 21, 2011, 08:59:40 PM »
Offline Elsifer
« Reply #9 on: August 22, 2011, 07:34:07 AM »
Now that, is one nice bumper + tire carrier!
VA6CPL
Jeepless....
