Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Jack Stands
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Jack Stands (Read 1111 times)
WK2008
UberWheeler
Jack Stands
on:
August 22, 2011, 10:10:17 PM »
Its me again he he, just wondering what I should pick up for a jack and jack stands. I don't really understand the ratings on them and being that my grand is lifted, I would like something that will actually get it off the ground.
Logged
Zombie
UberWheeler
Jeff the Zombie Jeep
Re: Jack Stands
Reply #1 on:
August 22, 2011, 10:25:46 PM »
I would think some 6 ton ones would do, have some at PA for 60 bucks, min height of 15.5 inches, max of about 23 inches.
Logged
97 Red XJ, 4.5", 31" mud's, ARB front, 9500lb winch, bushwhacker's, warn sliders, HnT SYE and CV drive shaft - written off and sold for parts
WK2008
UberWheeler
Re: Jack Stands
Reply #2 on:
August 22, 2011, 10:58:06 PM »
Thanks Jeff. I will check them out tomorrow.
Logged
JackstandJohnny
Talks waaay too much!
where Jeeps go to die
Re: Jack Stands
Reply #3 on:
August 23, 2011, 06:03:42 AM »
i have 2 5tonnes which i use for suspension work and basically supporting the frame of a jeep when you need it off the ground. also have a set of little 2 1/2 tonne ones which work great for everything else.
might as well get a good 3 tonne floorjack and don't bother with a little guy. its money well spent!
Logged
~ rescue green JKUR on 35s. typical rubicon build
cLAY
Re: Jack Stands
Reply #4 on:
August 23, 2011, 03:12:41 PM »
Even the smallest jack stand will support the weight of one corner of your Jeep. However once a Jeep is lifted its about how tall the stand goes. A higher rating "usually" is taller and has a wider base(more stability). For my lift I use 6 tonners set on top of some old wheel rims to get the height I need.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Jack Stands
