Author Topic: 98' ZJ Stuck in part-time 4x4  (Read 2797 times)
Offline BIGJAMES
« on: August 27, 2011, 10:52:08 PM »
hey everyone i have a 1998 ZJ with the 4.0l I-6 i went 4x4ing today and everything went well but when i was done i tried to put it back into 2wd and it was really hard to move the shifter I think its stuck in part-time and theres no way to move it, it also make a hard clunking noise if i back up or go forward or turn sharpe. Any help is very appreciated
Re: 98' ZJ Stuck in part-time 4x4
« Reply #1 on: August 27, 2011, 11:08:43 PM »
Are you trying to shift while the trans is in gear?
Should be in neutral, rolling forward at about 5kph
« Reply #2 on: August 28, 2011, 12:53:29 AM »
You can try neutral. Or park, reverse and drive... Sounds like your driveshaft u-joints and axle shaft u-joints are shot. Gear selection won't fix that.
Were you in low range all day?
If your t-case linkage looks ok, I'm assuming the non maintenanced jeep had oiling issues inside the tease and something is now siezed up inside.
Offline BIGJAMES
« Reply #3 on: August 28, 2011, 12:27:35 PM »
So i got it to pop back into 2wd but the tranfers case was full of oil/muddy thick stuff I also found a line disconnected its just hanging there attacted to the front diff. I cleaned out the TC and refilled it with clean fluid I havent tried putting it back into 4x4 yet. Thanks everyone for the reply's
« Reply #4 on: August 28, 2011, 12:47:23 PM »
sounds like its time for a diff service as well.
might wanna change out the tcase fluid again in a little bit too..............  mud = jeep death
Offline BIGJAMES
« Reply #5 on: August 28, 2011, 04:26:01 PM »
im gonna change it in a day or two Its still not100% when i turn shape it make a clunking noise Hopefully i can figure it out and dont need a new TC......Im glad i didnt buy that 3.5" lift for it yet....
« Reply #6 on: August 28, 2011, 10:04:53 PM »
unit bearing or ujoint up front.................. :)
Offline BIGJAMES
« Reply #7 on: August 29, 2011, 12:57:53 PM »
it has a hard time shift back into 2wd the linkage pops off cause i push to hard When it is in 4wd or part-time it clunks reqally bad and hops when i turn or go straight
It also has a whinning noise on drivers side front and a clunking noise not nearly like it does when in 4wd. Ive changed out the TC fluid and it was cleansd I also put new fluid in front diff. My U-joint on drives shaft and axels are tight
Offline CatSplat
« Reply #8 on: August 29, 2011, 05:57:37 PM »
Check the joints on the front axle shafts, especially if they are CV joints. If there's any grease leaking out or noticeable tears in the boot, that's a good indication it's toast.
Jeep of Theseus
« Reply #9 on: August 29, 2011, 07:02:43 PM »
jack the wheel up and wiggle the tire. rock it back and forth?  do you feel anything?  a little clunk?  spin the tire; hear a click.
the sounds you indicate only lead to three things.  ball joints, unit bearings or ujoints.  if its not one of those three, then  :'(
Offline BIGJAMES
« Reply #10 on: August 30, 2011, 07:03:04 AM »
i really think its my unit bearing and axel U-joints. They are getting replaced on Thursday Is the Unit bearings are in the hubs so the whole hub needs to be replace im gathering?   THANKS for all the help
« Reply #11 on: August 30, 2011, 07:17:14 AM »
yes it is a complete unit.  fairly easy to swap out, especially after you've done a couple.  ujoints suck.  but they are doable too.  grab a haynes manual; it will tell you how to do this all.
good luck
Offline BIGJAMES
« Reply #12 on: September 01, 2011, 06:48:35 AM »
Well yesterday i took it to my Mechanic friend and we went throught the ZJ we discovered that the chain in the T-C is slipping  So I went and grab a 242J and will be installein it this weekend
Offline BIGJAMES
« Reply #13 on: September 01, 2011, 03:19:39 PM »
Just a quick quesation: Would a bad transfer case cause any lurching  and once you step on it it levels ups well today i had the tranny felt like it was in netural i checked and topped up fluid and its working fine again and the radiator fluid was low aswell
« Reply #14 on: September 01, 2011, 03:37:13 PM »
were you playing in deep mud?  stuck at all?  might wanna flush yhour tranny and replace the filter.  water and ZJ tranny's don't mix
