Author Topic: TJ Track Bar Bushings  (Read 1664 times)
Offline scott slade
  • Amboy... Route 66
« on: September 14, 2011, 04:09:34 PM »
Just picked up the used track bar from "firsttimer".. thanks, Kyle.  It's a stock bar from his 02 TJ, I might as well change the bushings and tie rod looking end to keep things tight, when I put it in my 05.  Who sells the parts and has a press to remove and install the bushings etc...?   ???
2005 LJ, Six Speed,
 16" Moab Rims
Re: TJ Track Bar Bushings
« Reply #1 on: September 14, 2011, 04:38:09 PM »
you can't change bushings/balljoint.
if its sloppy ya gotta live with it.
gotta buy a new one.   so you might as well go aftermarket.
Offline Elsifer
« Reply #2 on: September 14, 2011, 05:54:57 PM »
Bushing is changable. Needs persuasion. Balljoint end, not so much.
Moog has a bushing, I don't have a part number handy tho.
Stock bushing is one piece. Moog is a two piece.
VA6CPL
Jeepless....
Offline scott slade
  • Amboy... Route 66
« Reply #3 on: September 14, 2011, 07:48:45 PM »
I thought the bushing end could be replaced, but was not sure about the balljoint end.  The rubber boot on the balljoint is a bit ripped....  crap...
2005 LJ, Six Speed,
 16" Moab Rims
« Reply #4 on: September 14, 2011, 08:07:30 PM »
ya man. i know the balljoints not replaceable.
i think you can replace the bushing, but you need a press. its a pain.  its just easier to buy a new one...............
« Reply #5 on: September 14, 2011, 08:13:36 PM »
It was probably pried off using a large hammer and pickle fork  ;D
If the joint doesn't have slop in it it should be fine, but it probably won't last too long.
Offline AV.NINE
« Reply #6 on: September 14, 2011, 08:17:34 PM »
 ;D
Offline FirstTimer
  • Gettin there!
« Reply #7 on: September 14, 2011, 10:35:17 PM »
I did my best not to wreck it...   :-[ and Worked with what I had... For what it's worth it was free and technically it is still useable, you will just have to grease it on a more consistent bases.
Offline Raspberry
« Reply #8 on: September 14, 2011, 11:44:27 PM »
The bushing end is replaceable. No need for a press. If you have a propane torch and a vice it will help :)
Replacement bushings cost about $15-20. Modern Motors sells both the Energy Suspension and Moog variants, those are the one's I'd recommend.
« Reply #9 on: September 15, 2011, 07:31:17 AM »
just run it for now.  don't bother with the bushing.  a new track bar is under 100$ at autovalue anyways.  if you're keeping it stock it'll probably be fine for a while.
then when you get deathwobble one day, you'll know to change it!
Offline scott slade
  • Amboy... Route 66
« Reply #10 on: September 15, 2011, 08:03:33 AM »
Hey Kyle,  I can't Thank You Enough for what you did to get me this track bar.....  I just thought it made sense to put new ends on it before I installed it.   I mean no offence at all.   Thanks to all of you for you help and advice.....  Scott ;D
2005 LJ, Six Speed,
 16" Moab Rims
