Author Topic: 2010 Jeep won't start. Help  (Read 1669 times)
Offline dck77
« on: September 18, 2011, 05:57:51 PM »
I have a 2010 jeep wrangler 4 door that won't start. My wife left the keys in all night in  the on pos. Everything has power windows, radio lights ect. Its auto and i tryed putting in netrual to push it out of the grage to boost it but it will not change gears. What the hell. I know lots about jeep but this has got me really fumed lol. HELP. 403-613-4469 Donald
Offline scott slade
  • Amboy... Route 66
Re: 2010 Jeep won't start. Help
« Reply #1 on: September 18, 2011, 06:06:50 PM »
Hey Don,  a lot of times you may have enough power to run accesories but not enough to turn over the engine.  Could be as simple as letting it charge up and give it a try.  Make sure it is fully in park too.... some wierd safety switch may be at play too to stop it from turning over if not in Park.  Not sure why it won't go into neutral with the key on..?   Just some thoughts, keep us posted......
« Last Edit: September 18, 2011, 06:42:56 PM by scott slade »
2005 LJ, Six Speed,
 16" Moab Rims
« Reply #2 on: September 18, 2011, 06:38:21 PM »
There is a nuetral safty switch. There should be a little round plastic plug close to the shifter. pop this of and stick any type of screwdriver in there and push on the bottom and move the shifter at the same time. It should shift into nuetral then. This is the tow truck interlock switch if you want to call it that. most new vechicles built since like about 2005 have this.
Offline homeguy
« Reply #3 on: September 18, 2011, 08:04:23 PM »
I've got a 2010 too. This happened to me once.  Found out even if the battery looks like it's holding a charge if it drops under 11 volts the engine won't start.  Charge it for a while and you should be good to go.
Offline Jeepless
« Reply #4 on: September 18, 2011, 08:31:18 PM »
 I also had the same problem. 2010 JK auto. I diconnected my neg battery cable for about 5 min. Re-connected it and it fired right up. Never had the problem again. No idea what it was.
« Reply #5 on: September 18, 2011, 09:47:14 PM »
You could also shift the t-case in N to roll it out of the garage and boost it.
Offline BUKI
  • Project Fugly
« Reply #6 on: September 21, 2011, 10:59:43 PM »
kinda stupid question if its a 2010, cant you call roadside assist?  they can boost it in your garage.
« Reply #7 on: September 21, 2011, 11:27:58 PM »
You ever wonder sometimes when people post tech questions and 3 days later still have not returned to reply, THANK, etc :shakinghead:
