Author Topic: Different off set rims = new alignment?  (Read 2341 times)
Offline JKaJayF
« on: September 22, 2011, 10:46:52 PM »
can someone tell me if I will need to redo the wheel alignment if I get a new set of mags with a different off set? :-\ thanks
follow the gravel....
2.5" Old Man Emu heavy kit
37’s
XRC front & rear with 10000 X2O winch
Re: Different off set rims = new alignment?
« Reply #1 on: September 22, 2011, 10:52:03 PM »
no you will not need an alignment .
« Reply #2 on: September 23, 2011, 09:46:04 AM »
Offset on your mags will push or suck the wheels in or out from the Jeep. The only reason you would need to realign is if you disconnect any of your steering components.
Offline Moezer
« Reply #3 on: September 23, 2011, 05:24:57 PM »
does that include shocks and springs?
« Reply #4 on: September 23, 2011, 07:32:07 PM »
depends on the height you go you will need to have your steering wheel adjusted but no alignment will be needed ..   most TJ's can get awy with 3 inches of lift with out adjusting your steering wheel . i just installed 3.25 inchs on a JK and the owner said he steering wheel was out just a hair from where it was when it was stock but lifting will not affect the actual wheel alignment
its hard to explain on message because i cant point to the parts and pieces
your alignment is only disturbed is you play with your tie rod ends or drag link .  so dont touch those
Offline Raspberry
« Reply #5 on: September 23, 2011, 08:49:43 PM »
Also if you touch your rod too much or too often, you may go blind.
Offline JKaJayF
« Reply #6 on: September 23, 2011, 08:50:25 PM »
thanks guys 8)
37’s
Offline JKaJayF
« Reply #7 on: September 23, 2011, 08:54:50 PM »
I know raspberry...thank  god for women ;)
37’s
Offline Raspberry
« Reply #8 on: September 23, 2011, 09:05:52 PM »
Who cares if THEY go blind, right?  :D
Offline Moezer
« Reply #9 on: September 25, 2011, 10:25:22 PM »
ahh nice thanks for the info dude :D i only lifted it 2 inchs lol
