Author Topic: never build a ZJ......  (Read 58504 times)
Offline FirstTimer
  • Gettin there!
Re: never build a ZJ......
« Reply #105 on: November 05, 2012, 11:28:09 PM »
Did you not find the unit I told you about from JB Electronics on 32nd? I wired mine all up and it works perfect with the taurus fan, 3 way switch and all!
« Reply #106 on: November 06, 2012, 08:07:48 AM »
Link didn't work Kyle. Fire it to me again I will take a look.
Offline FirstTimer
  • Gettin there!
« Reply #107 on: November 06, 2012, 10:27:28 AM »
Here you go dude;
Wiring harness and thermostat controller (MFA 100)
http://www.maradynehp.com/products/accessories/wire-harnesses.php
JB Power Centre Website (Calgary Location at the bottom)
I also picked up a laundry list of extras from PA, 3 way switch, wiring, adhesive foam strips (place between fan and rad), fuses, watertight plastic container to house relay harness.  If you'd like I can come by one night and show you the set up.  If I can do it (with help from Buki) you can too!  :P
« Reply #108 on: November 06, 2012, 08:22:10 PM »
For the fuse holder I pulled a bunch of the wiring from the car with the fan, including the fuse holder. I believe it was a 60 or 70amp fuse.
« Reply #109 on: December 09, 2012, 10:01:17 PM »
update;
still need to do my efan and stuff.  that got on the back burner.  but, new toys in;
IRO long arms woop!
the bad; driveshaft was seized solid when we went to install it friday night; and found a blown hub bearing. stupid jeeps.
and for pewps and giggles, the truck; fresh from BrokenAxle with a 2" lift and 33" toyo open country ATs...... yes i'm running toyos lol
« Last Edit: December 10, 2012, 09:12:09 AM by JackstandJohnny »
« Reply #110 on: December 10, 2012, 08:01:08 AM »
22" Toyos
« Reply #111 on: December 10, 2012, 09:50:34 AM »
22" Toyos
fixed.  33's lol.
big thanks to Fraser and Dingman for helping me install it all friday night too
« Last Edit: December 10, 2012, 09:33:40 PM by JackstandJohnny »
« Reply #112 on: December 19, 2012, 12:41:25 PM »
well, quick update because i'm bored as hell at work. i gues people don't like to discuss their investment portfolios when its almost Christmas break ;)
put my new driveshaft in, it bolted up nice, kind of rerouted the exhaust a bit to clear the IRO cross member, hammered/cut some more fender on teh passenger side (maybe my axles bent; lol donno)
and hooked everything back up.  rides and drives nice again.
now she's all ready for the zombpocalypse ;)
« Last Edit: December 19, 2012, 12:43:48 PM by JackstandJohnny »
Offline Pookapotamus
« Reply #113 on: December 19, 2012, 01:41:41 PM »
not pictured above:
Costco size tub of Vaseline. :P
and yes i am a little bitter that your jeep runs and mine does not! >:(
« Reply #114 on: December 19, 2012, 04:39:01 PM »
hmmm...wierd. i always thought Toyo offered a man version in that size...
 ;D
Those long arms look beefy!
« Reply #115 on: February 16, 2013, 06:50:12 PM »
so update.
last time out wheeling i broke some stuff. no surprise there.
so new goodies came in.  new 33" tire, and IRO double sheer track bar and currie lync steering, and some 5.5" coils.   steering was a little 'tweaked' lol
also burnt a driveshaft up, it was vibing pretty bad. didn't get that installed yet though :(
« Reply #116 on: February 16, 2013, 10:21:07 PM »
Steering got tweaked ? People say the V8 ZJ steering is supposed to be an upgrade for TJ's and XJ's? < snicker>
« Reply #117 on: February 16, 2013, 10:25:16 PM »
I'm just that good Noel. I can break anything
« Reply #118 on: February 17, 2013, 10:32:52 AM »
Or the stock TJ is just REALLY crappy.......
« Reply #119 on: February 24, 2013, 10:43:10 PM »
did some more fun stuff.  blew out the IRO joints on my arms. decided that replacing them with the same would just lead to similar failure. plus they werne't adjustable, so i can't pop the axle out further to run 35s in the future ;)
so decided to go with johnny joints instead................  stan had em to me overnight, which is good, cause i'm impatient ;)  got some jjs and weld in bungs; now, the control arms aren't the righ ID for these, but having friend swith lathes is great!
gotta say i'm happy with how it turned out. control arm surgery is fun Johnny Joints for the win!
