Author Topic: Extended Brake Lines  (Read 2389 times)
Offline yellowjeep101
« on: October 05, 2011, 06:49:49 PM »
I'm sure this has been covered in a topic already, but being my phone won't let me search (yes my phone), I'm wondering where I can get some extended brake lines made? Thanks for any suggestions.
Offline BUKI
  • Project Fugly
Re: Extended Brake Lines
« Reply #1 on: October 05, 2011, 07:20:35 PM »
national, modern, northridge, summit racing, quadratec, they all have pre made for lift sizes.  where to get custom made lines I dont really know
« Reply #2 on: October 05, 2011, 07:21:04 PM »
stan @ northridge
« Reply #3 on: October 05, 2011, 07:27:08 PM »
Thanks. Ill check them out and see what I can come up with!
Offline cuzican
« Reply #4 on: October 05, 2011, 11:34:00 PM »
If you don't need stainless you can swap stock Chevy lines on front for about 4". Readily available and cheaper.
I would have to look in shop for part numbers I used but I originally got info from a link like this one
http://www.universityofjeep.ca/Tech/Brakeline_Upgrade/JeepTJ.htm
« Reply #5 on: October 05, 2011, 11:42:18 PM »
donno if TJs are the same as ZJs, but i'm using YJ stock brake lines, they are 3" longer than stock
Offline jeepjones
« Reply #6 on: October 06, 2011, 04:15:40 AM »
Modern usually has Stainless braided extended lines in stock unlike National which seems to have no stock and everything has to be ordered and is always 3 weeks away.
« Reply #7 on: October 06, 2011, 02:23:45 PM »
Oddly enough, national had them in stock. Fantastic! Thanks everyone for the speedy replies.
Offline Fredduck
  • RIDE ON
« Reply #8 on: October 06, 2011, 05:53:36 PM »
Greenline across Blackfoot trail from National.
Custom stainless brake lines
« Reply #9 on: October 06, 2011, 06:04:09 PM »
I bought the skyjacker stainless steel off the shelf from national. Of course it was easy to install  and no wait
