Author Topic: front wheel bearing, 04 rubicon  (Read 4721 times)
Offline Elsifer
« on: April 14, 2006, 01:57:24 PM »
Anyone know where I can get a passenger side front wheel bearing for an 04 Rubi??
I have my rig up on blocks, the ujoints seem fine as there is no binding when I turn the wheels, plus the sparrows seem only to come out when there is more rotation than what my hands can provide.
There is slop on the passenger wheel, but it looks like the balljoint/kingpin is ok. The slop seems to sound like grinding (metal on dust) and it seems to come from my rim against the wheel assembly. So I assume bearing.
Anyone have the necessary tools and stuffs to do this? I can't get to it this weekend, as I am in school and poor, but I do have some cash coming my way next week, so I can get it done then.
Thanks in advance!
Chris
VA6CPL
Jeepless....
Offline apex
« Reply #1 on: April 14, 2006, 03:05:55 PM »
Chris, I went thru the same thing myself a couple months back with my front D30. Used unit bearings are $75 at jeepstuff. They had to dig to find a match for me. Auto value new ones are around $150-175. Must order them tho. Talk to bnine if you want to go this route. I had to buy a hub puller that you are welcome to. Most people are able to flip the rotor and use it as a slide hammer. I couldn't get it budge this way hence the need for the puller. Everthing else was just hand tools, some grease, and beers. I can help with the tools if you help with the beers. ;)
« Reply #2 on: April 14, 2006, 04:30:33 PM »
I got my last wheel bearings @ National... they are called "FAG" ....  :lol:
They werea bit cheaper than Auto Value.  :D
My first set I got from A.V. near Heritage and Macleod and they cost me $156 tx in each (for a D30).  It's all the same crap.
Don't buy the "better" ones (at about $250) you will have to change them in a year anyway.
Greg ... Chris... BEER soon Tabarnack :?: !!! :P
Offline apex
« Reply #3 on: April 14, 2006, 05:27:48 PM »
i think we should just get a case and "help/watch" chris change his unit bearings.
Offline TJ54
« Reply #4 on: April 14, 2006, 05:44:00 PM »
Wouldn't a '04 be under warranty still ?
But if you want to do yourself, I would be willing to help, It is a easy job and a minimum of tools are needed, I have done mine a couple of times now. Just come on out and visit one evening, The last one took me less than an hour.
« Reply #5 on: April 14, 2006, 05:44:55 PM »
Quote from: "apex"
You have my vote....  8)
I'll even volonteers to do one side!!!
Luxton
« Reply #6 on: April 14, 2006, 06:13:28 PM »
part source is selling them for $240.99.... the more expensive truly don't make a difference?  found out when I changed my tires over to the 31s that at least my passenger side needs attention... but I'd really like to save that $100!  that's a TON of beer! :D
« Reply #7 on: April 14, 2006, 07:13:48 PM »
Quote from: "Luxton"
I looked at both on them and I also try them both. One looks a little stronger than the other but they look very simillar. I'm sure the more $$$ ones are a bit better... not $100 better! With the beating I give my bearings (water, mud, tire size) more $$ or cheaper ...they last me about a year away.
$100 X 2 bearings ... THAT'S ALOT OF BREWSKIS  :shock:
That's my 2 cents...
Cheers....     ?//////?
henry
Wheel Bearing
« Reply #8 on: April 15, 2006, 09:39:15 AM »
Chris
I have (3) longer 12 Pt bolts that will fit in and repace the ones holding your wheel bearing assemblies in.  Just pull out the three orignal ones, install mine and tap on them with a hammer instead of the original bolts.  The wheel bearings pop out very easily, with zero damage to anything else.  The only difficult part is getting the large nut off the axle, but its not bad if you have an impact gun.  But it can be done other ways also.  Simple job, just expensive.
 8)
Let me know Chris and I'll show you.
Darren
Offline Rig-Pig
« Reply #9 on: April 15, 2006, 11:10:12 AM »
just a quick heads up as well.....  make sure you torque the large center nut to specs.  i did it old school, back when it only had to be just over hand tight, and i ended up replacing the bearing again 2 months later...
build 'em, break 'em,
love 'em, leave 'em
same thing
Offline apex
« Reply #10 on: April 15, 2006, 01:35:06 PM »
hey rigpig... what is the torque spec on that nut? I gotta make sure i did it right.
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #11 on: April 15, 2006, 03:38:28 PM »
I bought a set off ebay 3 days ago.  With shipping to my door and exchange, two are coming to $223 Canadian.  They are made by Atlas who is owned by Transbec.  The last ones I bought were through Napa and I think they lasted a less than a year.  These ones can't be any worse.
He put another set up for auction.  Here's the link:
http://cgi.ebay.com/ebaymotors/90-99-jeep-tj-yj-wrangler-front-hub-and-bearing-NEW_W0QQcmdZViewItemQQcategoryZ33564QQitemZ8056475085QQrdZ1
HTH,
98 TJ 4" lift + goodies
Offline RckyMtnTJ
« Reply #12 on: April 15, 2006, 04:16:05 PM »
I guess I should mention that these units on ebay aren't for your year, but he might be able to get some for you.  He buys and sells these things wholesale.
Jeff
Offline Elsifer
« Reply #13 on: April 17, 2006, 09:06:45 AM »
Hey, thanks for all your suggestions and offers. I'm waiting for some funding to hit my bank, and then I can go get the bearing kit. But I'll prolly be doing my wrenching this weekend, so everyone, put saturday on your calendar, bring your lawnchairs, you might have to sit out in the alley as the garage is pretty small.
But seriously, if you are interested, sat morn/afternoon I'll be wrenching, then sat night off to KOTC!  :twisted:
PM me!
Cheers
Chris
VA6CPL
Jeepless....
Offline Elsifer
« Reply #14 on: April 18, 2006, 03:57:00 PM »
I was down at National yesterday, and yes Dom, the FAG wheel bearings are what I am going to be putting in.
This Saturday, late am, my house (unless someone wants to volunteer their garage, mine is pretty small for heckling).
PM me for directions, bring your own chair, covercharge to watch the festivities is a case of beer - which you get to drink! But I get one or two.
Cheers
Chris
VA6CPL
Jeepless....
