Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Durango Steering Box Swap and resultant issues - need advice
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Durango Steering Box Swap and resultant issues - need advice (Read 1392 times)
TJ Sparky
Budget Lift
on:
October 16, 2011, 11:30:51 AM »
So after reading about the Durango Steering Box swap I decided to pull the trigger and swap mine out. The original one in the TJ was leaking really bad; worked fine but leaked a ton and went through buckets of fluid. The swap was really easy and only took about 2 hours. BUT now that it's all done he are the issues I'm having:
- steering wheel is no longer centered (take the wheel off and re-center?)
- when I turn left it really wants to go left/when I turn right it really wants to go right. (probable allignment?)
Any ideas? Has anyone else done this swap?
Thanks!
Logged
If you are looking for a cheap hobby that will get you out into the woods, collect rocks or bird watch........don't buy a Jeep.
Raspberry
Budget Lift
Do what you love, the rest will follow.
Re: Durango Steering Box Swap and resultant issues - need advice
Reply #1 on:
October 16, 2011, 11:53:11 AM »
Can you not adjust the steering wheel position by adjusting the drag link?
Logged
DECEASED - 'Big Ben' (black '97 XJ) : ~9" lift - 35's - Ford 9" - 4.56 gears - armoured up - ...and a sound system that can annoy the hell out of Lemon-aid Jay!!
NEXT - Dark green '98 XJ to build up....
JENSSEN
Talks waaay too much!
Reply #2 on:
October 16, 2011, 11:58:20 AM »
So it turns too quickly? If I remember correctly my XJ box was 3.75 turns lock to lock, the Durango box was 3 turns lock to lock.
Logged
www.racingforthecure.ca
Rookie
CJA Members
That CB Yapper
build it, break it, rebuild it better
Reply #3 on:
October 16, 2011, 12:05:37 PM »
Here's the info you need for centering the steering
http://www.stu-offroad.com/steering/align/align-1.htm
and as long as it gos left when you turn the steering wheel left and right when turned right it sound like it works like it was intended to remember your comparing it it to an old and possibly worn out steering box
Logged
TJ with some stuff
TJ Sparky
Budget Lift
Reply #4 on:
October 16, 2011, 12:21:47 PM »
I double checked the measuments for the "toe in" and I'm an inch out. I loosened the two clamps to adjust it but the damn adjusting sleeve won't budge........FML
Logged
yellowjeep101
Budget Lift
Reply #5 on:
October 16, 2011, 01:00:17 PM »
After loosening the clamps, lots of lubricant to break the sleeve loose, and a screw driver in the crease on the sleeve.
Logged
TJ Sparky
Budget Lift
Reply #6 on:
October 16, 2011, 04:05:44 PM »
After PB Blaster, a torch. a ton of swearing and a pipe wrench the adjustment bar broke loose. I got it all working again. Thanks to all for the help!!!
Logged
FiEND
Wrecking Ball
Reply #7 on:
October 16, 2011, 11:35:14 PM »
my tool of choice mmmmhmmmm
Logged
1Wide2High
ILV2FRT
'97 TJ [sold]
'17 JK Rubicon
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
