Author Topic: Driveline vibration  (Read 2817 times)
Offline WK2008
Driveline vibration
« on: October 20, 2011, 07:16:34 PM »
So I bought NUXJR's Rango and I'm happy with the purchase. I am having an issue with a driveline vibration and it's through the whole rig. I checked the normal stuff like tires and wheels and there is no issue there. I am at a loss and not sure where to start next. Any suggestions as I will get Jay @ Chanda to look at it but not sure what would cause this
Offline esi
Re: Driveline vibration
« Reply #1 on: October 20, 2011, 10:02:08 PM »
U-joints
a crappy CV shaft
Warped rotors
Ball joints going
Formerly of Boots & Boost Inc
« Reply #2 on: October 21, 2011, 07:48:26 AM »
Take it back to the seller and get them to figure it out ;D
Sorry Rob, I could not resist
Offline NUXJR
« Reply #3 on: October 21, 2011, 07:58:23 AM »
Was telling John yesterday it's just that his azz is way more sensitive than anyone elses....take that however ya like it :o ;)  Sorry John, was totally set up by yourself ;D :P
But seriously folks, ball joints just 2 yrs old, pwr slot rotors less than 2 yrs old and babied, last time I checked u-joints were all fine, CVs are hard to diagnose without taking out.  I dunno, the slight vibes I picked up on once and a while I figured were just prolly tire related.  Hopefully Jay comes up with something that ends up simple.
Offline esi
« Reply #4 on: October 21, 2011, 09:05:46 AM »
Could easily be a wheel balance issue. Hard to tell without throwing them on a machine. A memory foam seat cushion might be a simple solution :)
« Reply #5 on: October 21, 2011, 04:00:17 PM »
Is it lifted? If so then check the rear shaft angle.
« Reply #6 on: October 21, 2011, 05:22:10 PM »
loose pinion is the source of my vibes
Offline WK2008
« Reply #7 on: October 21, 2011, 05:40:02 PM »
I am leaning in this direction and the driveshaft direction. Everything else seems to be in good order. Thanks for the tips guys.
Offline Alltornup
« Reply #8 on: October 21, 2011, 06:49:38 PM »
At what speed is it vibrating??
Offline WK2008
« Reply #9 on: October 21, 2011, 08:24:52 PM »
Between about 85 and 110 and it's not every time as if it were tires. It seems to be worse under load for sure which leads me back to driveline
Offline WK2008
« Reply #10 on: October 23, 2011, 04:45:48 PM »
So it appears I have found the culprit. I learned something new about lug nuts when you buy new wheels. The typical hub centric OEM wheels will used a normal 60 degree tapered lug nut where most aftermarket wheels require new lug nuts which are still tapered but have a shorter taper and a bulge at the start of the taper. The bulge plays a key role in centering the lug nuts to the wheel and ultimately centering the wheel. This is not such a huge concern with hub centric aftermarket wheels, but more if they are lug centric for multiple vehicles with the same bolt pattern but different hub diameters. In the end, the lug nuts from the OEM wheels were used, as I have done in the past, and ultimately was not allowing the wheel to be centered on the lugs. I also learned it is super important to tighten the nuts by hand first and then hand torque the wheels. Again, not such a huge concern with OEM wheels, but if you have aftermarket wheels it's probably best to only use the impact for removal and not installation. I hope this helps someone else too as I will be picking up some new nuts tomorrow from Wheel Pros and this should fix the problem. I spoke to McGard and they told me this is why almost all aftermarket install kits for non OEM wheels are the bulge acorn style not just the 60 degree acorn style.
Offline binare
« Reply #11 on: October 23, 2011, 04:49:25 PM »
As a side bonus: Youll get those lug nuts off when the impact aint handy. I always tighten by hand.
Offline WK2008
« Reply #12 on: October 23, 2011, 05:29:55 PM »
It Will be a practice I will follow now for sure. Impacts really can make a mess of a wheel or studs in the wrong hands
« Reply #13 on: October 23, 2011, 10:06:49 PM »
So how did you come to this revelation?
Offline WK2008
« Reply #14 on: October 24, 2011, 09:01:28 AM »
After every other option was exhausted I went to wheel pros and this is what they have suggested. When in doubt, ask the experts.
