Author Topic: 2007 JK  (Read 1619 times)
Offline Tomtwoshoes
2007 JK
« on: October 31, 2011, 07:30:30 PM »
Hello I have 2007 JK  I have replaced the master cylinder and the slave cylinder because of weak clutch pedal, about 800km ago, Now every morning when I go to drive the JK  I cant shift because I again have a weak clutch pedal dose anyone have any ideas I about ready to put an auto in  !!!  Here is the troubling part if you drive the JK for about 15mins the clutch works great ?????
Re: 2007 JK
« Reply #1 on: October 31, 2011, 07:57:24 PM »
Did you bleed it?
Re: 2007 JK
« Reply #2 on: October 31, 2011, 08:13:17 PM »
My xj is the same way. Bled many times but still got an air bubble in there somewhere.
Re: 2007 JK
« Reply #3 on: November 01, 2011, 12:32:38 PM »
Try bleeding it from the bottom up. Just pull the slave and work the piston manually till you get bubbles out the top. I've never been able to bleed them that well out the bottom.
Offline Tomtwoshoes
Re: 2007 JK
« Reply #4 on: November 03, 2011, 03:42:11 PM »
 :( >:( :'(   Well The JK is at the shop  Clutch is good  some were along the line somebody put the wrong oil in the master cylinder  and now it is eating all the rubber seals,    FXXK   and  NO one will say they did  that so now the JK will have all new rubber hoses and anything rubber in the hydrical system  the grand total will be around $3750.00     So much for buying that 6inch lift kit now will just have to live with the 4" and and 35" tires for now  FXXK FXXK FXXK
Offline binare
Re: 2007 JK
« Reply #5 on: November 03, 2011, 05:36:42 PM »
4 grand for rubber??? where yu take that too
Re: 2007 JK
« Reply #6 on: November 03, 2011, 10:03:44 PM »
Am I missing something here? Almost 4 grand for a clutch master cylinder, 1 line and a slave cylinder?
Offline Tomtwoshoes
Re: 2007 JK
« Reply #7 on: November 03, 2011, 10:10:21 PM »
Just not the master cylinder and slave  But every thing   brake lines and calipers ABS brake modula   and labour
Re: 2007 JK
« Reply #8 on: November 03, 2011, 10:17:58 PM »
RUN!!! Fast to another shop for a second opinion!
Unless you filled both brakes and clutch  master with bleach, then you deserve the 4k bill  ;D
Re: 2007 JK
« Reply #9 on: November 04, 2011, 07:47:58 AM »
This.
