Author Topic: dana 60 with 70 shafts  (Read 1999 times)
« on: November 03, 2011, 09:32:37 PM »
ok guys fast question
i have a dodge dana 60 SRW full float rear diff and it has 30 spline shafts   im wondering if a 35 spline shaft from a dana 70 SRW will be the same lenght and flange size
does any one know
this would save me money on buying aftermarket shafts   and i can just hunt down some dana 70 shafts
Re: dana 60 with 70 shafts
« Reply #1 on: November 03, 2011, 09:49:40 PM »
I remember Steve Jueco had some minor issues running 35 spline shafts in his rear 60, I believe he had to have the tube ends bored bigger to fit the larger shafts (I'm not 100% positive what part but I know he had to have something drilled out bigger).
Vince
Offline AV.NINE
« Reply #2 on: November 03, 2011, 09:50:47 PM »
ppffftt puny little 30 splines...  ;)
Still springs all 4 corners?
Offline raf2379
« Reply #3 on: November 03, 2011, 09:57:11 PM »
The spindle needs to be bored out to accept the 1.5" shafts, but i'm not sure about the lengths of the shafts if they would be the same or not.
« Reply #4 on: November 03, 2011, 10:32:46 PM »
I thought some 70 spindles were the same as 60's?
So many variations of both 60 and 70, SRW and DRW... I don't think you can say a 70 shaft will fit, or not fit.
Search Dana 60 bible to see exact specs of what you have, length, diameter, spline count, coarse or not, bearing sizes, etc... Then cross reference that into the Dana 70 bible  :)
After all this work, you'll most like explode that tiny little 5:38 pinion before anything else ;D
« Reply #5 on: November 04, 2011, 12:13:34 AM »
I already checked for the spindle and I have 1.65 inchs.  So I have space for 35 spline 1.5 inch shafts
Not worried about the pinion I'm running a stock motor
Checked the bible and no such luck.  I did find a guy that had a 60 an a 70 and in his post it showed the 60 shafts in the 70 and the flange end was the same
But I was hoping maybe someone had a more for sure answer
« Reply #6 on: November 04, 2011, 09:17:11 AM »
You should be able to buy brand new chromo's for somehwere in the 400$ range. Wreckers will charge half of that at least to break open a 70. I would look at new.
« Reply #7 on: November 04, 2011, 09:20:34 AM »
I got my yukon cHrOMO shaft for $150 a side...
« Reply #8 on: November 04, 2011, 09:25:28 AM »
Why you gotta use the franglais spelling, Dom? In hen-gleesh it's spelt crOHMO
« Reply #9 on: November 04, 2011, 11:31:39 AM »
where did you get yours .. and are they 35 spline \
« Reply #10 on: November 04, 2011, 12:29:05 PM »
I'm running 5.38s and 36" IROKS on my rear d60 with stock shafts. Its in my 5500#, V8 ZJ and its the only part of the drivtrain I have not broken. That axle is now on its 3rd wheeling rig and has been bullet proof.
I would leave the shafts alone and spend the money elsewhere.
« Reply #11 on: November 04, 2011, 02:22:36 PM »
They are 30 spline FF ....
« Reply #12 on: November 04, 2011, 05:49:35 PM »
i already order a 35 spline spool for the rear .. so shafts have to be up graded . :)
no choice
