Author Topic: 1994 yj transfercase  (Read 1326 times)
Offline new2jeepguy
« on: November 04, 2011, 10:55:46 AM »
im looking for a transfer case for a 1994 yj standard  4litre   anyone have one  ?its says 231 j   on the tag.l  will a cherokee t/c fit?                                                           thanks i got one
« Last Edit: November 07, 2011, 07:09:17 PM by newjeepguy »
Re: 1994 yj transfercase
« Reply #1 on: November 04, 2011, 11:17:34 AM »
Yes an XJ t-case will work
« Reply #2 on: November 04, 2011, 06:10:56 PM »
correct me if im wrong here Scott, but the xj 231 is clocked lower then the wrangler unit. not sure how much but i think thats what ive read somewhere before. it will bolt up though. no vacuum actuator though.
Offline All Juiced Up
« Reply #3 on: November 04, 2011, 06:41:25 PM »
Your completly right clocked wrong and no acuator
« Reply #4 on: November 06, 2011, 08:38:03 AM »
The vacuum actuator is easy to switch over and the clocking is lower but it is from the transmission and not the t-case.  So if you use an XJ t-case with a YJ tranny, it will be fine
« Reply #5 on: November 06, 2011, 09:37:53 AM »
aahhhh, i see. the clocking on the transmission makes more sense. i wasnt certain about the vacuum actuator. instead of swapping it over it might be a good time to get rid of the vacuum system. posi-lock or one piece shaft.
Offline Uboatcmdr
« Reply #6 on: November 06, 2011, 05:18:42 PM »
I have put two xj transfer cases in my '91(first blew up) only difference i ran into was the front output.
Since the xj has a double cardon i had to get a U bolt set for it but it works great.
