Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
no heat
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: no heat (Read 1241 times)
new2jeepguy
Budget Lift
no heat
on:
November 10, 2011, 10:10:39 AM »
I put a new rad in, new thermostat too as I had a rad leak. Now I've got heat but it,s not very hot?
its the 4litre engine any ideas?
?the thermostat I put in is a higher temp one so it should blast out real hot but noooooooooooooooooooooooooooooooo!
Logged
esi
That CB Yapper
Re: no heat
Reply #1 on:
November 10, 2011, 10:15:38 AM »
Airlock in the system
Logged
Formerly of Boots & Boost Inc
TL-Iguana
Talks waaay too much!
XJ - The Official TJ Rescue Vehicle
Re: no heat
Reply #2 on:
November 10, 2011, 11:24:42 AM »
Yeah, sounds like you have air in the system. Take the rad cap off with the engine cold, start up and run it till its hot, with the heat on high. Should hopefully circle the coolant through the system and push the air to the top of the rad... Of course if your heater core hoses are higher than your rad cap then the air will go to the highest point.. but this is most likely whats happening. Unless your thermostat went in upside down... in which case its not flowing any coolant
Logged
I did a Google search for "hot trannies" but nothing came up about oil coolers
'01 XJ on 35s, '11 Jk DD
new2jeepguy
Budget Lift
Re: no heat
Reply #3 on:
November 19, 2011, 05:27:22 PM »
thanks i,ll try the air lock thing
Logged
SkatersTj
Budget Lift
Re: no heat
Reply #4 on:
November 20, 2011, 11:53:08 AM »
I have the same issue, little heat on low settings but on high it's cold air almost. My friend suggested it's the heater core needing to be replaced? Could that be the issue, -20 sucks driving to work in the morning
Logged
JamesEmergencyEvacutionPlan
1997 Tj sport 3" lift 31's
1982 Cj8 scrambler 4.5' lift 35's
___/|¯[_\__\],
l¯¯¯l¯¯L-O|||||O_
¯()_)¯¯()_)¯¯¯()_)
new2jeepguy
Budget Lift
Re: no heat
Reply #5 on:
November 20, 2011, 12:04:51 PM »
yup it was suggested that i run C.L..R. thru the heater core and c if that helps if its not an air block issue hmmmm may be both when i flushed out the system it was full of discolored crap and sediment I flushed the heater core out both ways and it was better but I guess it could still be crappy and semi plugged inside any one/ have a heater core?
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
no heat
