Author Topic: broken chevy starter  (Read 1077 times)
Offline i_go_commando
« on: November 12, 2011, 06:59:45 PM »
in my 58 fc170 i am running a 700r4.
well today i went to move it. started and stalled. tried to start again and the starter just spun.
removed the mini starter and the shaft was in 2 peices. I cant get the peice that turns the ring gear out. does it have to come out from the traany side of the starter mount? and other ideas
it is not jammed on the gear as i can turn the motor by hand
tommorow morn ill go get a new starter and try and move it into the garge with a towbar.
then i guess i pull the tranny. any other ideas?
Offline Fredduck
  • RIDE ON
Re: broken chevy starter
« Reply #1 on: November 12, 2011, 08:14:26 PM »
It should all come out from the starter side.
« Reply #2 on: November 12, 2011, 11:16:43 PM »
TH350 and 700R4 should be just about the same... The starter should just come out like any other... Perhaps take a pic and post it so we can see what you mean? The flywheel should be just that... a flywheel, with nothing attached to it from either side. The starter should have the small gear inside the housing of the starter, and that comes out as a unit with the solenoid attached...  ???
