Author Topic: Idle drops to 200 or so after gas/acceleration  (Read 1194 times)
Offline spoons72
« on: December 01, 2011, 11:03:36 PM »
2000 Jeep TJ 2.5 l.  I just replaced the motor (used one from wrecker) as the previous owner blew a head gasket and cylinder wall was trashed beyond repair.  New motor is great and drives well.
Only issue is that most of the time after hitting the accelerator while parked or driving it will drop down to 200 or so rpms, almost stall and then come right back up.
I've been told to check for vacuum leaks.  What's the best way to check for vacuum leaks?
What else might it be?
Re: Idle drops to 200 or so after gas/acceleration
« Reply #1 on: December 02, 2011, 12:38:46 AM »
Can of brake clean or carb clean. Spray it at vacuum lines and if the idle changes then you probably have found your leak.
« Reply #2 on: December 02, 2011, 05:46:47 AM »
Leaky egr valve?
Offline Unknown303
« Reply #3 on: December 02, 2011, 07:06:06 AM »
TPS?? When mine went on my TJ is would do weird things when trying to accelerate.
Offline hornblower
« Reply #4 on: December 02, 2011, 09:27:25 AM »
I would say it sounds like a TPS.
Preparing For the Zombie Apocolypse.
Offline binare
« Reply #5 on: December 02, 2011, 12:50:16 PM »
Funnel and hose works too to listen for the leak.
Offline xjpete
  • New ride
« Reply #6 on: December 03, 2011, 08:03:25 AM »
get it warmed up then spray the idle control valve with throttle body cleaner when its running , sometimes they get gummed up
97 XJ,8'' LA ,35's , SBC .
98 ZJ daily driver .
Offline spoons72
« Reply #7 on: December 08, 2011, 09:02:32 PM »
Thanks for the responses.  I'll be trying some of them tonight.
