Author Topic: JK Aux iPod cord  (Read 1460 times)
Offline Mud
  • Chad
JK Aux iPod cord
« on: December 12, 2011, 08:18:20 PM »
Which cord are people running their iPods with?
1. 3.5mm on both ends
2. 3.5mm on one side and 30 pin on the other
I have the 3.5 on both sides but doesn't charge and sounds like sh!t. I can only find the option #1 and   #2 is available from china or the dealership ( which will charge $150).
Hoping to hear what's workin or if the #1 option is  best.
JKU-R, RK 5.5 Lift, 36" IROK, WARN 8274,  CB, Genright tire carrier, Poison Spyder Armor, Warn Bumper, Viair
RIP 2001 Orange TJ
Offline Knox
Re: JK Aux iPod cord
« Reply #1 on: December 12, 2011, 08:22:58 PM »
correct me if I'm wrong, but the 3.5mm plug doesn't transmit any power, so even option 2 wouldn't charge?
2003 TJ
Offline binare
« Reply #2 on: December 12, 2011, 08:33:39 PM »
Nope your right... and theyll sound the same too.
Offline Mud
  • Chad
Re: JK Aux iPod co
« Reply #3 on: December 12, 2011, 09:13:07 PM »
Boom! That's what I was afraid of. I have a cradle with the 30 pin end but it causes sooooo much interference when it's plugged in. I had a way better result in my TJ where I had a FM transmitter hard wired - it had a 30 pin coming from the glove box and charged the iPod and the sound was good enough for a jeep.
Thanks guys.
RIP 2001 Orange TJ
Offline AstraX
« Reply #4 on: December 12, 2011, 09:18:20 PM »
What year is your JK?  and which radio do you have?
Offline Mud
  • Chad
« Reply #5 on: December 12, 2011, 09:36:18 PM »
I have an 07 unlimited rubi.
The stereo looks like this:
http://reviews.cnet.com/2300-10863_7-6582576-13.html?s=0&o=6582576
Also, if anyone knows how hard it is to get the u-connect enabled from a jeep dealer that would be great too. From what I understand, just because you have the uconnect button, doesn't mean you have the functionality... Mine just says "u-connect not available" when I push the button.
RIP 2001 Orange TJ
Offline AstraX
« Reply #6 on: December 12, 2011, 10:26:26 PM »
Mopar e-store lists it at $356.00.  You would be better off buying an aftermarket deck.  You could get a nice deck, installed with bluetooth and ipod compatibility for that much.
Offline hornblower
« Reply #7 on: December 12, 2011, 10:28:57 PM »
if you press u-connect and it says not connected you need to have it installed.
Alternativly you can get a good aftermarket unit for half the price and it will have a better stereo.
Preparing For the Zombie Apocolypse.
Offline Mud
  • Chad
« Reply #8 on: December 12, 2011, 10:47:25 PM »
Perfect. New deck it is. Not used to all the high-tech gadgetry in a Jeep that is just going to inevitably be beat on the trail! Oh well, might as well do it new millennium style (blue tooth and iPod ready!).
RIP 2001 Orange TJ
Offline AstraX
« Reply #9 on: December 12, 2011, 11:01:58 PM »
Drop me a line I can see about helping you out a bit.  I work for Best Buy.
Offline homeguy
« Reply #10 on: December 13, 2011, 09:40:47 AM »
I Changed out the stock radio and put an Alpine IXA-W404.  Has the direct connect to the ipod, charges it, loads the music up and plays in 6 seconds from start up.  Hooked up a couple of amps, new speakers and sub... pounds like a champ
