Author Topic: Noisy front locker, is that normal?  (Read 985 times)
« on: December 24, 2011, 10:58:17 AM »
05 Rubicon LJ.
When I rotate one wheel by hand, there is a rumbling noise/feel coming from the front diff. If I raise both wheels and engage the locker so both wheels turn in the same direction, there is no noise and it's nice and smooth. It sounds like spider gears are not meshing properly (assuming the front locker has spider gears) is that normal?
I bought this rig about 1,500 miles ago and changed oll fluids before I drove it, the old fluid came out in good shape, no unusual metal particals and the fluid was clean but not too clean like it was just changed.
I did not pull the cover yet and thought I would post up and see if it's normal or not first.
The Jeep has 75k miles and is all stock except for the 33 Engineering skid I installed.
Any input?
Vince
Re: Noisy front locker, is that normal?
« Reply #1 on: December 24, 2011, 03:17:51 PM »
Ok, I pulled the cover and the fluid came out like new, very, very little fine metal on the magnetic drain plug, more like a powder than filings.
Everything looks good but when I put a stethescope on the cross pin that holds the spider gears, I get a definite tick-tick.....tick-tick.....tick-tick at about the frequency the spider gears mesh with each other.
I visually inspected the spiders through the holes in the carrier and didn't see any obvious signs of damage but of the 4 gears, I could only get a visual on 3 of them.
I guess the next step is to pull the carrier and remove the spiders for a thorough inspection.
But before I do that, anybody happen to have a Rubicon on stands that could spin the front wheels and check for me? May save me messing around if it's normal operation.
Vince
« Reply #2 on: December 24, 2011, 09:30:06 PM »
I would say ur spiders are worn a bit.
But I never had any issues with my rubicon with the stock lockers
« Last Edit: December 24, 2011, 09:31:37 PM by Rubi03 jef »
« Reply #3 on: December 24, 2011, 09:59:36 PM »
Any ideas where I can get replacements or should I bother? the FSM as well as Jeeps parts list show the carrier as an assembly and no separate internal components.
Vince
« Reply #4 on: December 25, 2011, 06:39:24 PM »
run her till u cant stand the noise then change it out for a better locker
no point in changing it if it still works
