Author Topic: AEV jk 3.5 lift install  (Read 1314 times)
Offline jkroller
« on: January 06, 2012, 03:28:40 PM »
i willl be installing a aev 3.5 lift over the weekend and was wonding if any one was around to lend a hand and some input on the install would be great msg or txt if intrested  403 462 3007
09 jk aev 3.5in prem  lift, 33" toyo open country m/t on 18"s ,warn m8000, xhd front winch bumper with push bar, xhd rear bumper, bushwacker flat flare, garvin roof rack n ladder,
Offline heep-a-lop
  • EMF WHORE
Re: AEV jk 3.5 lift install
« Reply #1 on: January 06, 2012, 03:46:31 PM »
i should be around if u need soem assitance slash tools... if u have air i can bring my mac toys
Offline jkroller
« Reply #2 on: January 06, 2012, 04:43:38 PM »
i jus got stuck into working but it will be getting done next sat for sure so  if ur still around it would be great and i have a full shop with lift and air
Offline Pinchy
  • '97 TJ & '95 YJ
    • Trails4Tomorrow
« Reply #3 on: January 08, 2012, 08:51:48 PM »
FYI their instructions are terrible, not sure what year you have but if it's 2011/2012 your brake lines are too short if left attached to the clip under the spring seat and long enough to get in the spring if you take it out of the clip.  AEV told me to loosely zip tie the lines to the shock to avoid that problem, but I think a better option would be steel braided lines routed properly. :-)
