Author Topic: Replacing the rotten old rusted out tub  (Read 1223 times)
Becker
« on: April 23, 2006, 02:09:02 PM »
Well, as I was starting to see a light at the end of the tunnel on the YJ for another season of carnage, today I ventured into repairing/replacing the body lift.
Upon further inspection, the side mounts on the tub (under the doors) are all cracked.  It appears that the previous owner torqued the hell out of the mount bolts pulling the tub down into the mount, thus resulting in weakness and eventually cracking.  I figure that instead of throwing more time cutting, patching and welding on a tub that is already in pretty rough shape it may be better to just pull it off and replace it.
So heres the question, how much work am I looking at in replacing the tub alltogether?  Any hints or past experiences or grief that anyone wants to offer up?
I figure while I am at it and the dash is all out I will explore the flat panel dash change over as well.  I found a pretty decent write up on it and it really doesnt look that difficult.
Any info that you can offer is appreciated.
The "Just Empty Every Pocket" is living up to its reputation!
Offline NS-jeeper
« Reply #1 on: April 23, 2006, 02:58:56 PM »
I switched a YJ tub on to a CJ and it wasn't all that hard, only a few things were diffferent, so changing a YJ tub to a YJ should be even easier, the only thing I found that was hard was the pedals as the cj has a different clutch set up.
Be Careful with a new/used  tub without the support of the frame they can bend slightly right at the doors.
Also I would try and get a tub from a standard if yours is standard or a tub from an auto if yours is an auto as they will have/not have the wholes punched for stuff like clutches, not that you cant cut them out or punch them out yourself but it will make it eaiser as there are also brackets for stuff on the firewall
Also there not heavy but lifting one is eaiser with a few friends, and beer always makes things go smoother  :wink:
