Author Topic: 2001 TJ Blower motor wiring schematic  (Read 1055 times)
Offline Chiram000
« on: January 23, 2012, 07:53:11 AM »
Ladies and Gents,
Would anyone happen to have a wiring schematic w/ colors for the blower motor, resistor pack and switch? In december I replaced the blower motor out on the jeep in hopes that it was the last of the lack of heat. It seems as if tracing the leads I've got switched power up to the resistor pack, good ohms across the resistor pack itself... but somewhere inbetween there and the harness we get down to about 0.25V. Realistically speaking if either the switch or resistor pack failed the fan should still work on high and defrost. Not to mentioned when straighed across the terminals of the battery the fan spins faster than Richard Simmon's in an aerobic video.
Until then a cheater relay will be wired in, but any help with wiring schematics from those of you who have a shop manual infront would be appreciated.
Cheers,
Tyler
