Author Topic: Dynatrac, Is there a Canadian company building axles like these?  (Read 2339 times)
Offline jeepjones
Just wondering if anyone knows of a Canadian company that builds axles like Dynatrac? If not what is the best place to order complete full axles from Dynatrac in Alberta?
Re: Dynatrac, Is there a Canadian company building axles like these?
« Reply #1 on: January 25, 2012, 01:11:34 PM »
theres a few shops that deal with the currie rockjocks... offhand i dont know if anyone has a direct account with dynatrac. if you really want dynatracs check their website for dealers.
« Reply #2 on: January 25, 2012, 02:36:39 PM »
Northridge in Ponoka sells complete axle assemblys as well as chanda with the currie line.
Offline LEMON-AID JAY
  • Bad a$$ zj owner
« Reply #3 on: January 25, 2012, 03:05:58 PM »
If your interested in any of the rock jock axles or other axles from currie let me know we are putting together a bulk order right now  ;D
http://www.currieenterprises.com/cestore/cjrockjock.aspx
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
Offline raf2379
« Reply #4 on: January 25, 2012, 03:51:58 PM »
Last time I looked into dynatrack axles I think the gear center could get some
Offline jeepjones
« Reply #5 on: January 26, 2012, 02:33:14 AM »
I was just inquiring, it will be a long time coming before I can spend that much all at once. I was hoping that maybe someone in Canada had jumped on it and was producing something along the lines of the Currie/Dynatrac/G2 axle line. That's too bad, but at the same time if I win the LottoMax this friday you'll know what I'll be doing, I'll be producing some serious Canadian Made custom axles/diff's.
Offline NUXJR
« Reply #6 on: January 26, 2012, 08:53:24 AM »
www.hoyboyz.com
Rob is a great guy to deal with ;)
« Reply #7 on: January 26, 2012, 09:11:09 AM »
www.hoyboyz.com
Is he still in business?
Offline NUXJR
« Reply #8 on: January 26, 2012, 12:28:06 PM »
Have not talk with him in quite a while but the site is still up.
Offline jeepjones
« Reply #9 on: January 30, 2012, 11:34:21 AM »
I've got a ford 9" out of a Lincoln Versailles that I'm going to build for the rear end instead, should be a whole lot cheaper than ordering anything.
« Reply #10 on: January 30, 2012, 01:05:45 PM »
Yeah but you get what you pay for. Should at least look at an aftermarket housing. They are cheap enough, and not nearly as prone to bending when brackets or trussing is welded in.
Low pinion 9's are hard on driveline angles, and prone to getting beat up a lot. I'd recommend a pinion gaurd as a minimum.
Stock 3rds have a tendancy to crack and or rip apart. I wouldnt do one if you are doing anything more then beadlocked 35's.
Unless you re drill the shafts and do an 8.8 brake conversion you are looking at currie shafts and an aftermarket brake kit, which might get spendy.
If you want cheapest there is jeep to jeep swap with reasonable strength, the 8.8 is the axle. It will be close to the strength of a stock 9, and a lot cheaper and easier to swap to a jeep.
Even getting fancy with a spool, super 88 kit, and new gears and bearings you are into an 8.8 for less then 2k if you are doing it all yourself.
Or for 1500 more you can do a spooled tru hi 9 with 40 spline semi floats, custom width, bolt pattern of choice, and 8.8 disks.
Clayton at evolution has the jig tool for welding currie big bearing 9" ends onto bare housings.
