Author Topic: Spark Plugs, Wires, Distributer Cap  (Read 2348 times)
RUBICON13
« on: January 30, 2012, 07:35:38 AM »
Well,
Due to some rough running and starting (on may 2007 JKU Rubicon; yes, mini van motor  :P) it appears it is time for some new spark plugs (137,500 km). I bought it used at 127,500 so, I don't know if plugs have been replaced before.
So, my question(s) is/are: what spark plugs do you recommend, and should I replace the wires and/or distributer cap too while I am at it? The wires seem to look fine but, I have not taken the cap off to look at it.
Thanks for your advice!
Jeff
Offline LEMON-AID JAY
  • Bad a$$ zj owner
Re: Spark Plugs, Wires, Distributer Cap
« Reply #1 on: January 30, 2012, 07:41:54 AM »
Only use Champion plugs in a Chrysler engine  ;)
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
RUBICON13
« Reply #2 on: January 30, 2012, 07:52:14 AM »
Jay,
Thanks for the advice. Any particular ones (i.e. double platinum tip V-groove etc)? Also, why only Champion?
Jeff
Offline apeman
  • not as grumpy
« Reply #3 on: January 30, 2012, 08:40:18 AM »
Black champion truck plugs.
Getting grumpier every day.
« Reply #4 on: January 30, 2012, 04:20:53 PM »
They discontinued those did they not? I havent been able to find them anywhere as of late :( If you have a supplier Aaron please PM me ill buy another set while I can. I tried switching to an Autolite that was recommended to repalce the Truck Plugs but they dont even come close to the Champions :(
« Reply #5 on: January 30, 2012, 04:29:02 PM »
Any reason for this or did you just buy a metric ton load of Thier stocks?   :)
  • Bad a$$ zj owner
« Reply #6 on: January 30, 2012, 04:56:12 PM »
I worked as a chrysler tech for 12 years and in that time I and the dealers found that champion plugs are the best match. Most other brands will give you problems sooner or later.
E-mortal customs
Phone 403-265-6669
Offline Knox
« Reply #7 on: February 02, 2012, 07:45:53 AM »
for the 4L TJ I've had these 3 recommended.
Autolite xp-985 iridium
Autolite double tipped platinum APP985
Champion 7034
if that helps at all
2003 TJ
RUBICON13
« Reply #8 on: February 02, 2012, 09:03:13 AM »
Guys,
Thanks for all of your tips.
I have gone with the Champion Double Platinum (Canadian Tire finally had 6 in).
But, I haven't heard any response as to whether I should replace the wires and/or distributor cap at this time. Any suggestions. The wires look fine but, I haven't taken the cap off to look at it yet.
Thanks,
Jeff
Offline binare
« Reply #9 on: February 02, 2012, 08:37:57 PM »
Do you have a dist cap?
Offline Anton
« Reply #10 on: February 03, 2012, 12:08:39 AM »
Jeff
I have the OEM Wires, Distributer of the JKU 2009 Sahara, if they are same as urs and you need them we can work something out.
I believe they where used for a bout a 1.5 years i think and then i bought the Performance Distributors Firepower Ignition Kit.
Anton
1996 jeep cherokee.
Offline Knox
« Reply #11 on: February 03, 2012, 07:17:24 AM »
But, I haven't heard any response as to whether I should replace the wires ...
It's almost never a bad idea to replace something in a jeep :P
whether its needed in your 07 idk, I'd plan on replacing mine on my 03 (if I had wires)
if they still look good, its your call but some people do it every two years
« Last Edit: February 06, 2012, 08:18:53 AM by Knox »
2003 TJ
RUBICON13
« Reply #12 on: February 03, 2012, 08:50:12 AM »
Thanks guys!
I hope to get to it in the next couple of weeks.
If they look good and fire fine after I replace the plugs I will leave them alone. If it ain't broke...
Jeff
