Author Topic: Streched YJ??  (Read 7026 times)
Offline R3DN3CK
Streched YJ??
« on: March 08, 2012, 12:37:38 PM »
So I ask a question here to see if anyone has attempted or done this, I have a 2 YJ Wranglers and a Full size Ford,
I seen one picture of a rig where a it seemed a YJ had its arse end streched out and then dropped on to a Ford frame,
It looked pretty good to me, not really 100%  Jeep anymore and no other info on the unit so I ask everyone on here
Am I crazy for trying to strech a YJ's back seat and dropping it on a full size frame?
Any thoughts or ideas?
Offline raf2379
Re: Streched YJ??
« Reply #1 on: March 08, 2012, 01:01:50 PM »
there are strech kits out there for YJ's, but thats to link and strech your wheel base, not the jeep tub itself. I have not seen a YJ streched tub if thats what your getting at.
some strech kits http://www.genright.com/category.aspx?categoryID=112
Re: Streched YJ??
« Reply #2 on: March 08, 2012, 01:24:17 PM »
cj's and yj's have been dropped on bronco and jimmy frames for years. Im sure there's a crap ton of red neck tech on it somewhere.
Re: Streched YJ??
« Reply #3 on: March 08, 2012, 01:31:05 PM »
I know a guy in Southern Alberta who has an 89YJ that he plunked on a 79 Ford Bronco frame . A 3" body lift was needed to clear and new body mounts were made. The radiator had to be located to the back of the YJ where the rear seat used to be because of fitment issues with the Ford engine being too snug under the hood of the YJ(fan too close to rad).
 The transmission tunnel , gas filler neck, wiring was also modified . It looks ok from a distance and I can understand his reason for wanting the benefits of a V8, stouter diffs etc but it's relegated mostly to mud-bog type wheeling .
It is possible to put a CJ , YJ tub onto something else and the Jeep purists might not like it but it's your rig. I had a 67CJ on a 78  3/4 ton GM truck frame and utilized it's stouter drivetrain  to handle the 38" Boggers. I didn't stretch the pristine tub at all but I bobbed the frame to the rear leaf spring mount and made a crossmember . You can cut up the rear of your YJ's tub to make one longer tub like a Scrambler?
My advice is to do more research and measure twice and cut once.
Re: Streched YJ??
« Reply #4 on: March 08, 2012, 01:36:24 PM »
I had alls muh teeth when I don did that's to muh CJ Billy. It werked goods and stuffs. :P
Re: Streched YJ??
« Reply #5 on: March 08, 2012, 07:11:42 PM »
You still had all your teeth when you did that, what were you? 6 years old? ;D
Offline R3DN3CK
Re: Streched YJ??
« Reply #6 on: March 09, 2012, 10:46:10 PM »
I'm pretty sure the pic i saw as it stated was a 88 wrangler body on 79 ford 250, good heavy strong motor and drive train, with the looks of a jeep...
Page 20, bottom left, of the Petersens 4 wheel magazine, pretty sure 1988 yj body was not offered stretched like this one,  my whole thing is i have  2 yj both run and that's bout it, a 79 bronco on propane with 38.5 swampers that have seen hardly any wheeeling so, i just trying to come up with a different looking type of rig...so many options......
gonna have to keep investgating,
Thanks for the info
Offline Impact
Re: Streched YJ??
« Reply #7 on: March 10, 2012, 05:25:50 PM »
Are you working with a Bronco/short box frame?
How much are you looking to stretch your YJ?
An option would be to stretch the rear to Unlimited TJ length and then you can get any accessories  for an unlimited if you need it. Top, armour, etc. That's what I'm doing with my TJ, swapping it on to an LJ frame and stretching the tub.
12 Crush JKU Sport
05 Orange TJ Sport-2" BB, 1.25" BL... (1 tons, 39's... Who the fawk really knows!)
92 Red Cherokee Sport-4.5" Rustys Lift, 33's KM2's, Eagle Rims(405k's n still tikkin...) Sold :(
Offline Mudhawg
  • Rig Life
Re: Streched YJ??
« Reply #8 on: March 14, 2012, 10:51:54 AM »
are you talking about something like this?
"1980 chevy k30 chassis shortend 40 inches D60, 14b, 350, TH400, 203/205 twin sticked, full hydro stearing, with a 1989 jeep wrangler body and 38.5x15x16.5 boggers that will soon be on H1 rims, just got to finish recentering them"
Offline Impact
Re: Streched YJ??
« Reply #9 on: March 17, 2012, 07:05:09 PM »
^Holy Fawk...
"LIKE"!
12 Crush JKU Sport
Offline R3DN3CK
Re: Streched YJ??
« Reply #10 on: March 20, 2012, 09:45:55 PM »
Sweeeeet... That 1980 Chevy-YJ, kinda what I'm talking about, I give that ride 2 thumbs up..
Offline Black Betty
Re: Streched YJ??
« Reply #11 on: April 20, 2012, 06:37:16 PM »
Google wagoneer springs on a Yj.  Basically buy two sets of wagoneer springs (IIRC fronts x2), slight modification to springs perches (weld and re drill) and you get 2" of stretch either end.
Stupid hurts
Offline cuzican
Re: Streched YJ??
« Reply #12 on: April 20, 2012, 10:25:02 PM »
Potential to buy a stretch project someone else started - not mine
This Jeep has been extended 14" tub and frame, has an AMC 360 engine swapped in a 727 transmission and 208 transfercase the diffs have been upgraded to dana 44's Also has a 4" suspension lift, LOTS of extra parts including brand new autometer gauges. Needs to be finished. This Jeep would make a great one-of-a-kind awesome 4x4 rig when completed. Moved, don't have the space or time to complete. Phone Steve for details - 403-894-0292
http://lethbridge.kijiji.ca/c-cars-vehicles-auto-parts-tires-auto-body-parts-Custom-1995-Jeep-YJ-W0QQAdIdZ362282327
Offline superles
Re: Streched YJ??
« Reply #14 on: April 21, 2012, 08:51:16 AM »
I think I just threw up a little.
