Author Topic: Rear turn signal issues  (Read 1445 times)
Offline Knox
« on: March 15, 2012, 09:18:29 PM »
So question for the electrical folks
Issue: My rear drivers side turn signal does not work. Verified with 4 ways, 3/4 flash fine, and left signal flashes faster.
Things already checked:
- Bulb is good, I can swap sides the bulbs only work on the right.
- Rear driving lights work fine
- Reverse lights work fine (I know different bulb, but same batch of wires running back there...) I did read a common issue with grounding that the reverse light can get a small bit of voltage leaking to it from the other one but, no, I don't have that issue,
- Took a voltmeter to the pads, and it fluxes up and down 9-10v then 2-4 etc. same as the right side, yet the left doesn't work...
So any ideas? All I can figure is take it apart, clean it all and redo the grounds?
2003 TJ
Offline jkrubi
Re: Rear turn signal issues
« Reply #1 on: March 15, 2012, 09:24:31 PM »
Have you tried it with a test light? If it flashes with a test light it's gonna be your ground.
You could try cleaning the bulb itself, tighten up the socket that it goes in ( ground ). Do you have continuity between the socket and the frame? If not its the wire itself.
Offline Knox
« Reply #2 on: March 16, 2012, 10:30:07 AM »
Got in the Jeep this morning, rear blinker didn't work (as expected) got to my sons dayhome to drop him off, and it worked... stupid electrical gremlins
2003 TJ
« Reply #3 on: March 16, 2012, 10:35:13 AM »
same thing happens to me all the time...
Offline Knox
« Reply #4 on: March 16, 2012, 10:46:10 AM »
So to fix it, do I need to start re soldering the contacts?
2003 TJ
« Reply #5 on: March 16, 2012, 10:55:27 AM »
Check in behind the body on the rear drivers side (access from underneath) I had and now have more loose connections in there...
Offline rws
  • Stump Grinder
« Reply #6 on: March 16, 2012, 03:06:12 PM »
This sounds like a broken wire that is inside a wire loom that is somtimes connecting and then not connecting. Also, check the common ground for your rear lights.
