Author Topic: How far onto splines shold my DS be?  (Read 1275 times)
Offline Marco
« on: March 20, 2012, 10:09:03 AM »
i been messing around trying to put a different transfer case in my 97 TJ. it appears now that the ouput shaft of my new one isnt quite the same. now that its all installed It looks like im only grabbing about  1 3/4" of splines. is that enough? i have room to extend the shaft another 1.5" but its $300. any ideas would be great thanks!
locked and loaded
Re: How far onto splines shold my DS be?
« Reply #1 on: March 20, 2012, 11:29:39 AM »
As long as you maintain decent engagement when the suspension if fully drooped, then you are fine. If you dont wheel, you are definately fine.
You should talk to Danco for driveshaft work. 300 to lengthen a shaft is really steep.
Offline AV.NINE
« Reply #2 on: March 20, 2012, 01:18:07 PM »
Bill sent me to Danco for my shafts. $150 to lengthen and balance. $100 to shorten and balance.
Offline Marco
« Reply #3 on: March 20, 2012, 10:28:03 PM »
Thats awsome fellas thanks for the info. i do wheel, but fairly conservatively so it may be ok. ill give it a shot.i have a 8mm wrench in my arsenal to come home in FWD if it decides to be too short  ::)
locked and loaded
Offline esi
« Reply #4 on: March 20, 2012, 10:46:02 PM »
With stock length suspensions the driveshaft will extend under compression of the  suspension, and compress when the suspension droops. You might want to try to compress the suspension and see what the driveshaft does.
Formerly of Boots & Boost Inc
Offline Marco
« Reply #5 on: March 21, 2012, 04:55:58 PM »
ive got a 4" pro comp lift and 1" drop on the skidplate. im gonna put it back together,  make some white chalk marks on it and use rti ramp to see what it does before i road test it i spose.
locked and loaded
