Author Topic: cherokee xj 98  (Read 4665 times)
Offline anjoxj98
cherokee xj 98
« on: March 27, 2012, 01:37:09 PM »
Hi my name is Angel , i have a 98 Xj  , 2 doors , manual
i want to lift my baby 4.5"  and i need some help because is my first project :D ,  the kit that i wanna buy comes with
    Front: Lifted coil springs, lower tubular control arms, solid tubular transfer case drop kit, sway-bar links and brake line relocation brackets.
    Rear: Add-a-leaf springs and lifted shackles.
    Shocks: Includes (4) RC N2.0 series shocks.
but i want to know if i have to change something else  like  the driveshafts? , because my  budget is 900$   :-\
Offline fug
  • Airdrie Pick n Pull
Re: cherokee xj 98
« Reply #1 on: March 27, 2012, 01:42:55 PM »
Transfer case drop will help you run the stock drive shafts for a while.
What brand of lift are you looking at?
Fug
TJ Rubicon
Offline anjoxj98
Re: cherokee xj 98
« Reply #2 on: March 27, 2012, 03:18:30 PM »
is Rough country , the total price , including shipping is 890$
Re: cherokee xj 98
« Reply #3 on: March 27, 2012, 03:35:50 PM »
I would go full rear leaves. Add a leaf on a fourteen year old spring? You will have leaf spring problems anywhere from one day to a year down the road. Are you getting your kit from north shore offroad in Surrey? They are a stocking rough country dealer. talk to them first.
Re: cherokee xj 98
« Reply #4 on: March 27, 2012, 03:59:29 PM »
Will at NSOR is awesome, bought my first lift from him and shipping was dirt cheap and FAST.
Offline anjoxj98
Re: cherokee xj 98
« Reply #5 on: March 27, 2012, 04:04:25 PM »
yes the kit comes with full rear leaves ...
Offline anjoxj98
Re: cherokee xj 98
« Reply #6 on: March 27, 2012, 04:19:26 PM »
but my question is , if i buy the 4.5 " , what parts i have to change ?
a friend told me that i have to change the pit-man arms , sway bars and track-bars.. if that is true i will spend like $1500 just in the lift kit
because my first option was 3"  or 3.5"  , where i don't have to change those things
Offline WagoneerXJ
  • Bagon Wagon!
Re: cherokee xj 98
« Reply #7 on: March 27, 2012, 04:49:47 PM »
The kit you mentioned listed "Add a leafs" Those are not full rear springs. At 4.5" you will need a new adjustable trackbar, or you get a drop bracket for the stock one, or even modify the existing bracket. Remove the rear sway bar and throw it in the trash. The kit you chose comes with extended links for the front sway bar. No problem there. Driveshafts should be ok.
84 Mustang GT-Built 351W 5spd
Offline anjoxj98
Re: cherokee xj 98
« Reply #8 on: March 27, 2012, 04:58:46 PM »
this is the kit that Im talking about
http://www.lowriders.ca/633N2-1984-2001-XJ-Cherokee-4-5-Inch-w-Rear-Leafs-p/rc633n2.htm
wagoneerXj , how much it gonna cost me those kits that you r talking about ? i mean if u have any idea , because my budget is not that good  :P
Re: cherokee xj 98
« Reply #9 on: March 27, 2012, 05:07:10 PM »
Will doesn't work there anymore BTW.
Offline Dingleberry
Re: cherokee xj 98
« Reply #10 on: March 27, 2012, 05:27:08 PM »
So, to be clear, does the kit come with full leaf-springs or just an add-a-leaf spring?
As for your other questions, it all depends on your 'cost vs performance' argument. If you're looking to do it on the cheap, you don't have to purchase anything extra:
In a perfect world, you want your trackbar and drag-link to run parallel with each other, otherwise on-road handling and comfort will start to suffer (things like bumpsteer, wandering under braking, etc). Once you lift a cherokee, these two components will sometimes be out of line with each other, so there are ways to get them back to being parallel.
The drop pitman arm is one option. The pitman arm bolts to the steering box and the top end of the drag-link. A longer pitman arm will drop the top end of the drag-link to a lower position which can bring it more into line with the trackbar. Personally I would go ahead with the lift first, and check after to see if a drop pitman arm is necessary in your case. If it is, a pitman arm from a Jeep Grand Cherokee (ZJ) 93-98 can be used for a 1" drop.
The trackbar centre's the front axle underneath the Jeep. Lifting the cherokee without doing anything to the trackbar will result in the front axle being off-centre, sticking out more to the driver's side. This isn't a huuuge problem but it can cause the notorious 'death wobble' problem. There is a simple fix for this without having to drop a couple hundred on an adjustable-length trackbar, and that is to drill a new mounting hole on the axle end, about 3/4" more towards the driver's side from the stock bolt mounting location. There are a few write-ups on the internet, just google em.
As for sway bar, you don't need to change it at all. What DOES become necessary is longer sway-bar links, which you stated was included in the kit, so you'll be fine there.
Personally I ran a 6" lift in my old cherokee, had the trackbar bolt re-drilled on the axle end (started getting death wobble and this fixed it), removed my rear swaybar completely (its not necessary, but the front one certainly is for driving around town), stuck with my stock pitman arm, didn't need a transfer case drop of any kind (make sure your driveshaft u-joints are good, and your pinion angles are set properly with axle shims if necessary), and even ran fine with stock length front sway-bar links (although they did sit pretty close to the coil springs though).
And this was my daily driver, it felt fine driving it around town, no driveline vibes, and when I got my first wobble I re-drilled the trackbar bolt location and that fixed it.
Offline Dingleberry
Re: cherokee xj 98
« Reply #11 on: March 27, 2012, 05:48:03 PM »
Judging from the link the kit you've selected comes with full rear leaf packs, excellent :)
Offline anjoxj98
Re: cherokee xj 98
« Reply #12 on: March 27, 2012, 06:07:24 PM »
so to be clear and i sorry i am a little bit nervous because is my first project  :P
well the ony thing that i have to fix is the track bar or buy a longer one ,  same thing which the pitman arm or use a zj 93 98 pitman arm
and maybe change the U-joints front the driveshafts  because they should have like 14 years old
thank for ur help  :D
Offline Dingleberry
Re: cherokee xj 98
« Reply #13 on: March 27, 2012, 06:13:05 PM »
Yes the trackbar will need to be fixed, either drill a new hole to re-mount the original trackbar or buy an adjustable trackbar.
Pitman arm either keep the original one as-is or a ZJ one can be bought for cheap at a junkyard if needed.
And definitely check all driveshaft and axleshaft u-joints to make sure they are in good shape.
Dracitamo
Re: cherokee xj 98
« Reply #14 on: March 27, 2012, 06:18:24 PM »
I had a 4.5" before I ripped it out and went 6.5". Stock driveshaft is fine in the 4.5". Not at all in the 6.5"  :-X
I'd highly suggest you don't go Add-a-leaf. Spring for the new leafs. It will save you a lot of hassle down the road. The kit you selected doesn't come with full rear leaf packs. What they show in the picture is the upgrade optoin, but what you get is Add-a-Leaf. Compare it to the manufaturer website and you will see. Here is a little comparrision I did for you.
Low riders 680.05 (the one you are looking at) including shipping
=TOTAL $715.00
Rough Country - Same kit you are looking at
Price: $499.95 - dropped to $459.95(same kit) Option: Also available with new rear leaf springs. +$221
= TOTAL $808.20 USD with new springs (including shipping)
=TOTAL $559.10 USD with add-a-leaf (including shipping)
Rough Country - w/ new leafs and other goodies
Price - 829.95 (new leafs)
=TOTAL= $988.8 USD (a little over your budget but worth saving up if you have a little patience)
If you are stuck on Rough Country (they are usually the cheapest out there) and have a little patience, maybe wait and see if Jay at Chanda will be doing a bulk order if he deals with RC?
You don't "need" all the stuff your friend told you but a little upgrade here and there doesn't hurt as the guys here have listed why and what to do. The kit you are looking at includes everything you will "need".
BTW: Not a fan of North Shore personally.
x2 on throw away the rear track bar.
