Author Topic: Any one have EVO NoLimits Manual Disconnect for a JK Rubicon?  (Read 2037 times)
Offline Mud
  • Chad
Any one try this solution to crappy e-disconnects on JK Rubicons? Looks real slick in the video.... Just wondering if Evo's solution works that slick after a day on the trail. For $99 looks worth a try?
http://offroadevolution.com/store/proddetail.php?prod=EVO-NOLIMITS
http://www.youtube.com/watch?v=X6e9TH_QgwU
« Last Edit: March 28, 2012, 08:32:10 PM by Mud »
JKU-R, RK 5.5 Lift, 36" IROK, WARN 8274,  CB, Genright tire carrier, Poison Spyder Armor, Warn Bumper, Viair
RIP 2001 Orange TJ
Offline LEMON-AID JAY
  • Bad a$$ zj owner
Re: Any one have EVO NoLimits Manual Disconnect for a JK Rubicon?
« Reply #1 on: March 28, 2012, 08:59:08 PM »
Looks like a good plan Chad.
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
Offline JENSSEN
    • Racing For The Cure
« Reply #2 on: March 28, 2012, 09:57:33 PM »
Wonder if EVO Calgary will challenge the name sake
www.racingforthecure.ca
Offline Mud
  • Chad
« Reply #3 on: March 29, 2012, 04:28:39 AM »
Wondered about that.. May be a cross border issue.
« Last Edit: March 29, 2012, 05:18:44 PM by Mud »
RIP 2001 Orange TJ
« Reply #4 on: March 29, 2012, 08:00:03 AM »
The place in the states is actually called "Off Road Evolution" or ORE. They make some VERY skookum JK suspension setups - like the EVO-Lever system.
As far as the "replace the crappy factory disconnect thingamajig" plan...yeah. I think that it's probably the way to guy if you're not just going to rip out the stock sway bar to put in an anti-rock or sway-lok. I'd choose that over "conventional" sway bar discos.
« Reply #5 on: March 29, 2012, 11:56:37 AM »
And the place called "EVO" in the Calgary area is no longer.
Name changed to EMF to get away from all the copycats, avoid confusion or something like that.
« Reply #6 on: March 29, 2012, 12:51:05 PM »
Is there no way to get a dual rate bar in a JK?
« Reply #7 on: March 29, 2012, 12:56:02 PM »
Answered my own question. As much as i usually dislike everything teraflex, this looks like a reasonable setup, and I dont see an ORO Swaylock anywhere for the JK.
Dual rate is always better then disco if you want decent performance out of a coil suspension. Disconnecting is just a band aid.
http://northridge4x4.com/shop/tera-flex-jk-new-forged-jk-dual-street-trail-rate-swaybar-4in-6-lift-1753725
« Reply #8 on: March 29, 2012, 02:16:47 PM »
ORO does make a Sway-Loc for the JK.
https://secure48.mysecureorder.net/offroadonly/catalog/index.php?cPath=56&osCsid=vff5ufctpn20794aq67cfn0001
The Teraflex system is probably fine....but I think that I'd probably lean towards the ORO.
Definitely more expensive than the ORE option...but you get what you pay for, right? I'd say that the ORE option is a better choice than conventional sway bar disco's, but only because it disengages the way bar without leaving anything dangling disconnected in your wheel wells. The sway bar links stay connected, which doesn't pose any sort of problem as long as they are the right length.
