Author Topic: Speedo Recalibration?  (Read 2530 times)
Offline MOABICON
  • MOABICON
« on: April 02, 2012, 08:05:09 PM »
Going up to 33"x12.50"x15" tires. Do I have to
go to my local 'Stealership' for a speedo recalibration?
 Stock 2003 TJ Sahara, 4.o litre, 5 speed.   :-\
Offline Jrama
Re: Speedo Recalibration?
« Reply #1 on: April 02, 2012, 08:11:13 PM »
you have to buy a new speedo gear, every place in calgary I have found is a complete rip off for a cheap arse plastic speedo gear (we are talking in the 90-100 dollar range for a little plastic cog... that costs like 30 bucks in the states)
Speedo gear is located on the T-case, on top of the rear output shaft and is held in place with one screw.
http://www.raingler.com/jeepreference/speedoChart.html
http://4x4xplor.com/speedo.html
Edit... I'm not sure as to the accuracy of the "raingler" chart...there is one floating around the Advance Adapters uses that is slightly off, I'm not sure if this is the one
« Last Edit: April 02, 2012, 08:19:42 PM by Jrama »
Offline MOABICON
  • MOABICON
« Reply #2 on: April 02, 2012, 09:35:10 PM »
That's great. Thanks for all the info.
I'm sure it will work just fine.  ;D
Offline Knox
« Reply #3 on: April 03, 2012, 08:14:38 AM »
I actually just priced one out at a dealership, I was thinking it wouldn't be too bad, it's a small part, plastic...
270$ is what I was told for a 37 tooth.
2003 TJ
Offline BUKI
  • Project Fugly
« Reply #4 on: April 03, 2012, 08:48:46 AM »
Totally confused I thought speedos on all 92+ were electronic and could be addjusted via elec devices doohickeys????????
« Reply #5 on: April 03, 2012, 09:56:20 AM »
You are right 92 to think 97 have both a gear that you can change , but it drives the electronic part at the transfer case. 97 and up ? the electronic part is in the transfer case.
Offline Dingleberry
« Reply #6 on: April 03, 2012, 11:33:16 AM »
Any way of ordering these speedo gears outta the states instead then? There's no way I'm paying $270 for that part (also need 37 teeth).
« Reply #7 on: April 03, 2012, 11:39:22 AM »
Try JustJeeps.com out of Ontario  - I have been successful with some better priced items from them lately...
Dracitamo
« Reply #8 on: April 04, 2012, 01:10:53 PM »
or you could always just use your GPS as a speedo, but that would result in lower km's on the odometer. it won't be off by that much. Maybe 5 to 10%.
Offline Dingleberry
« Reply #9 on: April 04, 2012, 01:26:26 PM »
I'm currently adding about 20-25% more than normal (4.56 gears with stock tires), until I can do the lift and fit the bigger tires. But man does it ever shift off the line pretty quick right now :)
« Reply #10 on: April 04, 2012, 03:05:10 PM »
Go to this link and trade speedo gears for the cost of shipping.
http://www.jeepforum.com/forum/f9/take-speedo-gear-leave-speedo-gear-643981/
Offline BUKI
  • Project Fugly
« Reply #11 on: April 04, 2012, 03:45:10 PM »
This is what I do. Have a 91 but swapped in a 94 tcase so no more speedo :'(
