Author Topic: Will 17x7" 44.45mm offset JK rims fit a WJ  (Read 1974 times)
Offline cvbbvc
« on: April 03, 2012, 04:09:20 PM »
anyone had experience doing this? these are the 17x7" rims (NOT 17x7.5"), 44.45mm offset, the WJ is 2002 stock limited.  THANKS
Re: Will 17x7" 44.45mm offset JK rims fit a WJ
« Reply #1 on: April 03, 2012, 09:52:50 PM »
yep rims should work.  bolt pattern is the same.  i believe WJ wheels were around 50mm of backspacing, so these should stick out a bit.
 JK take offs on a WJ?  cool!
Offline esi
« Reply #2 on: April 03, 2012, 11:20:18 PM »
I looked into this  a 32" might have some clearance issues with a stock suspension.  BB would be needed, or a bigger lift for  a wheelable WJ
Formerly of Boots & Boost Inc
Offline Moogs
« Reply #4 on: April 04, 2012, 08:46:13 AM »
minimum 3" to make em work ;)
ask me why i know lol
Offline cvbbvc
« Reply #5 on: April 04, 2012, 11:30:59 AM »
thanks guys for all the help.. saved me some headache. I guess the next question is what would be the smallest tire i can run on that rim so i can use the rims before i get around to lifting it?? Cheers
« Last Edit: April 04, 2012, 11:34:17 AM by cvbbvc »
Offline esi
« Reply #6 on: April 04, 2012, 03:25:12 PM »
265/65R17 works out to be 30.6" tall.   Available in a toyo OCAT.  Should fit.
