Author Topic: 231 fix  (Read 2946 times)
Offline OnyxGrizzly
  • Just another red XJ
231 fix
« on: April 17, 2012, 01:05:42 PM »
Just wondering how dificult it would be too pull apart my 231 and replace the chain? I am thinking of trying it myself.
Sent from my HTC-X710a using Tapatalk 2
If you don't stand for something, you'll fall for anything.
Re: 231 fix
« Reply #1 on: April 17, 2012, 02:06:57 PM »
if you can remove the transfer case from your jeep you should be able to pull apart the 231 and replace a chain.
i'd make sure you know its stretched/fubared before yanking it though....
Offline OnyxGrizzly
Re: 231 fix
« Reply #2 on: April 17, 2012, 02:16:36 PM »
Yeah I know for sure it is stretched haha, and I do have a haynes manual/ the internet to help me :D
Offline raf2379
Re: 231 fix
« Reply #3 on: April 17, 2012, 04:08:26 PM »
you can do it without removing the t-case, just get some good jack stands, such as the 12Ton Princess Auto ones.
Offline OnyxGrizzly
Re: Re: 231 fix
« Reply #4 on: April 17, 2012, 04:24:03 PM »
Sweet! That helps a lot since I know transfer cases are really heavy haha and I don't feel like pulling it out now.
Re: 231 fix
« Reply #5 on: April 17, 2012, 08:17:38 PM »
A 231 is not that heavy. I have no problem lifting them in and out by myself.
Just pulled a 247 out today.
Offline OnyxGrizzly
Re: Re: 231 fix
« Reply #6 on: April 18, 2012, 01:08:58 PM »
Ah I guess haha, it would be good experience to pull it, and my t case sometimes gets stuck in 4w that would be the chain, correct?
Re: 231 fix
« Reply #7 on: April 18, 2012, 03:14:43 PM »
Mmmm not really. Lots of other, simpler answers that should be checked first.
What brought you to that conclusion?
Re: 231 fix
« Reply #8 on: April 18, 2012, 03:20:32 PM »
when was the last time you changed the fluid in it?
Offline OnyxGrizzly
Re: Re: Re: 231 fix
« Reply #9 on: April 18, 2012, 03:54:35 PM »
about 4 months ago give or take
Offline OnyxGrizzly
Re: Re: Re: 231 fix
« Reply #10 on: April 18, 2012, 03:56:10 PM »
no idea haha, Its not all the time just every now and then it sticks for a sec then pops back out. So I guess its not really a very bog problem haha
Offline OnyxGrizzly
Re: Re: 231 fix
« Reply #11 on: April 18, 2012, 04:01:10 PM »
I am not very pro at knowing things. I learn as I go so I guess I should do some more digging in the interwebs haha
Offline Uboatcmdr
Re: 231 fix
« Reply #12 on: April 18, 2012, 11:22:44 PM »
Ibelieve the way to check the chain without tearing anything apart is to put it in 4wheel and check for excessive rotational play between the front and rear outputs.
Maybe someone else can chime in but I recall reading that on JF.
I was having similar issues and it turned out to be that my linkage was just out of adjustment.
Offline Black Betty
Re: 231 fix
« Reply #13 on: April 20, 2012, 06:02:50 PM »
What year is your jeep?  No chance it could be a sticky CAD?
Stupid hurts
