Author Topic: spare tire carrier antenna mount  (Read 3304 times)
Offline Ddub1973
« on: May 02, 2012, 07:28:43 AM »
Does anyone know where I can get one of these in Calgary for my 2010 JKU?  I could order one but I would like to have one for this weekend.
DDUB OIIIIO
2013 JKUR
Re: spare tire carrier antenna mount
« Reply #1 on: May 02, 2012, 07:42:59 AM »
Dean at the Road King will have something on hand.
Offline jeepgrl
  • All those JKs are starting to look the same...
« Reply #2 on: May 02, 2012, 09:34:55 AM »
I have a mount with two 3' antennas for sale. $20... PM me if you're interested.
Current project:
2012 2-door Orange Crush JK
AEV 3.5" lift
33" Mikey Thompson MTZ
Smittybilt XRC front and rear bumpers
Warn VR800 winch
BUILT AND SOLD: Silver 2007 JKU (because they all look the same now anyway)
Offline Ddub1973
« Reply #3 on: May 02, 2012, 02:49:20 PM »
Here is a picture of the one I am looking for.
DDUB OIIIIO
2013 JKUR
Offline Anton
« Reply #4 on: May 02, 2012, 02:57:36 PM »
I have this one, i bought it from northridge 4x4.
I would not use it if u have the time and get some else. The paint on it is not the best grounding and the area you mount it does not have a good grounding either. I had to sand the paint off from it to get a better reading but now the area with out the paint is rusting.
But in the end it works and i dont care any more lol.
Anton
« Last Edit: May 02, 2012, 04:04:27 PM by Anton »
1996 jeep cherokee.
Offline Ddub1973
« Reply #5 on: May 02, 2012, 03:10:41 PM »
I might just try an l-bracket from home depot then  :-\
DDUB OIIIIO
2013 JKUR
Offline Ddub1973
« Reply #6 on: May 02, 2012, 11:09:54 PM »
I used a 6" L-bracket from Home Depot and it worked awesome.  Had to cut it to fit and drill one hole.   ;D
DDUB OIIIIO
2013 JKUR
Offline Ddub1973
« Reply #7 on: May 03, 2012, 07:10:50 AM »
DDUB OIIIIO
2013 JKUR
Offline Anton
« Reply #8 on: May 03, 2012, 07:46:46 AM »
Looks even better! good job man.
Anton
1996 jeep cherokee.
« Reply #9 on: May 03, 2012, 08:12:51 AM »
That'll work!
You should also not have any issues with trail damage to your antenna given where it's mounted.
Offline Slewfoot
« Reply #10 on: May 03, 2012, 10:32:06 AM »
That'll work!
You might want to buy a small ball...tennis ball, squash ball, or something, (I have a small black squash ball), poke a hole in it and slide it over the antennt to line up with the wiper so you don't go insane with the sound of the antenna hitting the wiper.
Offline NUXJR
« Reply #11 on: May 03, 2012, 10:44:27 AM »
Yeah like he said!!!!
Where is the best place to ground when mounted in position?
« Reply #12 on: May 03, 2012, 11:04:16 AM »
That mount is grounded to the tailgate. There should be no need for any other grounding as long as the mount/bolt/nut/tailgate connection has nothing in the way (like paint).
Offline euroboxxer
  • My Red Rubi :)
« Reply #13 on: May 03, 2012, 11:13:53 AM »
i read somewhere that the tailgate mount isnt the best ground but i could be wrong. guess youll find out when you try to tune it with swr meter
2011 JKU Rubicon. Spidertrax 1.5" spacer. Uniden 520XL.
Offline Slewfoot
« Reply #14 on: May 03, 2012, 11:55:43 AM »
Mine is mounted on my tailgate.  I did nothing with the hinges.  I did make sure the bolts grounded to the tailgate (I ensured it was clean metal on metal contact) and have an SWR of 1.1/1.2 (can't remember which is channel 1 and which is channel 40)
I was suspicious of the tailgate mount, but W Squared assured me it would be OK - he was right. :-[
Now...if your hinges are all worn out and full of crud and corruption...that's a different story.  ::)
