Author Topic: I cannot get my CB radio tuned.....HELP!!!  (Read 3980 times)
Offline Ddub1973
« on: May 08, 2012, 08:01:51 PM »
I installed the uniden 520xl by running the power to a 12v adaptor.  I mounted the antenna to the spare tire carrier with a 6" steel L bracket from home depot.  I made sure to grind away the paint to get contact.  I ran a ground wire (14G) from the antenna to the bed of the jeep just to the right of where the stock jack goes and I also spliced a ground wire to the antenna mount to ground it to the same place.  You will see this in the attaced pictures.
I am not able to get a reading on channel 1 or 40 under 3 when I try to tune it.  Can anyone tell me where I am going wrong here?  This is obviously the first time I am doing this.
http://i1063.photobucket.com/albums/t516/ddub1973/IMG_2385.jpg
http://i1063.photobucket.com/albums/t516/ddub1973/IMG_2390.jpg
http://i1063.photobucket.com/albums/t516/ddub1973/IMG_2391.jpg
http://i1063.photobucket.com/albums/t516/ddub1973/IMG_2383.jpg
« Last Edit: May 08, 2012, 08:06:27 PM by Ddub1973 »
DDUB OIIIIO
2013 JKUR
Offline Hi Lo Silver
Re: I cannot get my CB radio tuned.....HELP!!!
« Reply #1 on: May 08, 2012, 09:04:52 PM »
« Last Edit: February 26, 2013, 06:36:01 AM by Hi Lo Silver »
« Reply #2 on: May 08, 2012, 09:33:40 PM »
You may lose a bit for the quick connect
You may lose a bit because your ground wires aren't matched impedance
You may lose a bit because its a jeep
You can run it at 3 , channels 1-40 don't matter , tune it for channels people use like 10-20
Mine and Bonnie's jeeps are mounted behind tail light and pull 2.5 on a good day but we consistently have very good quality sending and receiving so swr 3 and under is fine. If you're lucky and get better that's good.
« Reply #3 on: May 08, 2012, 09:54:19 PM »
Have you tried tuning it without the antenna ground connected?
Does the SWR meter tell you that your Antenna is too short (or too long) at both ends of the channel spectrum?
Offline Ddub1973
« Reply #4 on: May 09, 2012, 09:11:28 AM »
Both readings are just over 3 so I'm not sure where to adjust it.
DDUB OIIIIO
2013 JKUR
Offline Ddub1973
« Reply #5 on: May 09, 2012, 09:18:25 AM »
When you say you grounded your antenae....did you just run a ground from your copper braided ground wire to ground? If not then you need to as well as a ground wire from your mount plate to ground. I also run a ground from the CB unit body. I'd also ditch the  power plug kit and run the power directly to the positive on the battery. Gets rid of plenty of interference from all the rest of the electrical as well as engine noise.
Would you happen to have a picture of where I need to run the power?  How do I get to the battery?
DDUB OIIIIO
2013 JKUR
« Reply #6 on: May 09, 2012, 02:38:13 PM »
« Last Edit: February 26, 2013, 06:35:31 AM by Hi Lo Silver »
« Reply #7 on: May 09, 2012, 10:08:29 PM »
Passenger side, just inside the cowl. There's a bunch of foam up in there but it's easy to poke through. Just duct tape your wire to a coat hanger, and play fisherman. That'll get you power right off the battery.
You will need to know if your antenna is too short or too long. Adjust it all the way to the long end, then see what your SWR is. The try it at the short end, and see what your SWR is. Also, did you try with the "extra" ground disconnected?
Offline Ddub1973
« Reply #8 on: May 10, 2012, 07:20:43 AM »
Last night with the help of my wife holding the flashlight I was able to find a pathway through the firewall and run a power wire directly to the post on the fuse box and it was much easier to find a ground as there are a few right under the dash on either side. I removed the "over grounding" I did to the antenna and all I have to do now is mount the CB itself.
I'm going to mount it on the passanger side of the stick shifter and make it removeable. I'm going to find myself an open field after work today to make another attempt at tuning the antenna.  :D
DDUB OIIIIO
2013 JKUR
Offline Ddub1973
« Reply #9 on: May 11, 2012, 01:23:43 PM »
So I tried to tune my antenna today with no success. I was out in an open field with nothing around for interference. Still getting readings over 3.
Is there anyone that might not mind lending a hand to see how I have hooked this up and maybe get this working properly?
DDUB OIIIIO
2013 JKUR
« Reply #10 on: May 11, 2012, 10:46:46 PM »
Are your readings showing that the antenna is too long or too short? If its too short you can try adding a spring at the base.
Offline Ddub1973
« Reply #11 on: May 12, 2012, 03:11:36 PM »
I'm not real sure.  This is the first time I have ever tried installing a CB.  I get readings on channel 1 and 40 that are over 3.
DDUB OIIIIO
2013 JKUR
« Reply #12 on: May 12, 2012, 03:26:00 PM »
Sounds like the antenna is grounded out. Do not key your mike as the radio will short out.
Sent from my I junk
« Reply #13 on: May 12, 2012, 03:29:09 PM »
The inside wire should not be grounded out. Just the outside wire sheath.
Sent from my I junk
« Reply #14 on: May 12, 2012, 11:50:54 PM »
