Author Topic: CB Radio Question  (Read 1181 times)
Offline MOABICON
  • MOABICON
CB Radio Question
« on: May 09, 2012, 10:26:55 PM »
Does the CB unit itself have to be grounded. :-X
Re: CB Radio Question
« Reply #1 on: May 10, 2012, 02:16:37 AM »
yes.  there is a power + and a power - that should be attached to the battery.
there is a good chance the cb might work without the power - attached because it can steal ground from the antenna.
Offline Ddub1973
« Reply #2 on: May 10, 2012, 07:23:39 AM »
I ran my power + directly to the post on the fuse box and grounded my power - to a ground under the dash just last night.  Going to your batter can pick up interfearance if you have other things running to the battery also.
http://forum.calgaryjeep.com/index.php?topic=25453.msg159934#msg159934
DDUB OIIIIO
2013 JKUR
« Reply #3 on: May 10, 2012, 01:44:55 PM »
I ran both wires directly to the battery and used inline fuses in both positive and negative.
Vince
« Reply #4 on: May 10, 2012, 08:06:03 PM »
Battery is grounded to frame so you can ground the CB unit itself to anywhere on the frame.
