Author Topic: 97 TJ 5spd stuck in reverse  (Read 3986 times)
Offline WagoneerXJ
  • Bagon Wagon!
Re: 97 TJ 5spd stuck in reverse
« Reply #15 on: May 30, 2012, 04:43:50 PM »
Personally I would try the the slave first, see if its functioning, there may be a way to test that before anything else. And if not sounds like your pulling the transmission, new one or not, get a brand new clutch kit, and do it all while the transmission is off. Can you put shift gears with the jeep off?
No, I cannot move the shifter either running or with the engine off. Gonna check the fluid in it, and see if I can rock it back and forth and hopefully free it up....before I go yanking the transmission out.
84 Mustang GT-Built 351W 5spd
Offline yellowjeep101
« Reply #16 on: May 30, 2012, 06:07:23 PM »
Good idea, but it sounds like you will be pulling one soon. Hopefully she gets outta reverse. If you can look for a 3550, they are a strong transmission, still a 5 speed.
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #17 on: May 30, 2012, 10:17:30 PM »
I have a spare AX 15 but just don't want to swap unless I absolutely have to. Gonna try all the little stuff first
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #18 on: June 01, 2012, 11:42:39 PM »
Got it working again. Had to rock it and pop the clutch. Came right out
