Author Topic: Genrite Hi-Line Aluminum Fenders  (Read 2499 times)
« on: June 10, 2012, 03:32:26 PM »
Pretty straight forward. Definately recommend there for anyone doing new fenders. They actually weigh a few pounds less then factory fenders.
Few people have asked about these in the past, so here they are.
Re: Genrite Hi-Line Aluminum Fenders
« Reply #1 on: June 10, 2012, 03:45:52 PM »
these are damn sexy Bill... Did you have to cut the hood a bit? Look like you did. Nice clean job!
what you gonna do for the rear?
« Reply #2 on: June 10, 2012, 04:14:05 PM »
Thanks bud
I will  just raise the stockers and trim into the tub a bit, then seal it in. I cut the hood 3 inches.
« Reply #3 on: June 10, 2012, 05:15:57 PM »
I've got a set of the steel versions, very nice. They weren't as heavy as I thought they would be, but the alloy ones would be much lighter. Genright did a good job designing and building these units. If I recall that's a 4" lift and 33" tire so you've got plenty of room. Thanks for posting the pic, gives me an idea how mine should turn out.
« Reply #4 on: June 10, 2012, 05:26:53 PM »
That Savvy bumper is a very nice unit 8)  Something crazy like 16lbs right?
« Reply #5 on: June 11, 2012, 07:21:26 AM »
Yeah, if that. Its definately light weight. I did the rear as well. All in all this aluminum diet shaved just over 200lbs. Eventually when I change out the hard top doors I should net a total of 400 plus pounds.
Yeah, Eric. Tons of room. I am going to lose the lift springs and just run stockers with the extended shackles. Should bring it down 2-3". From there a 1" body lift, slam the belly, and tuck the tank. Savvy has a fuel tank skid for YJ's now.
It will be a while though. I just hit this one in my spare time between all the other stuff I do.
Offline BUKI
  • Project Fugly
« Reply #6 on: June 11, 2012, 08:43:48 AM »
« Reply #7 on: June 11, 2012, 09:50:22 AM »
Looks good Bill,
Is your own Jeep and if so, is it going to be a street driver instead if trail only?
Vince
Offline Nootch
« Reply #8 on: June 11, 2012, 11:07:15 AM »
what did you have to change underhood to accomodate the fenders?  pictures of the mods underhood if any?
« Reply #9 on: June 11, 2012, 11:44:31 AM »
Yeah its mine Vince. This is the drive to the trail, budget minded rig. Down the road I will mod the comp rig to be streetable as well, but just dont have the time or funds to tackle that right now.
Nootch, underhood Im using the genrite inner fenders. That part isnt done yet. Everything is just tied up for now.
You could re use the stock inners, but with the hiline it would get messy moving them up. Everything will be re hung in its original location using the new aluminum inners. It will just take some time and some finess.
Offline LukeDuke
« Reply #10 on: June 12, 2012, 04:23:16 PM »
Are you using the TJ inner fender kit? I didn’t think they made one for a YJ
RDJP President
http://www.reddeerjeep.com/
« Reply #11 on: June 12, 2012, 07:11:24 PM »
Tadaa: http://www.genright.com/ProductInfo.aspx?productid=TFF4SIF
Offline LukeDuke
« Reply #12 on: June 12, 2012, 09:13:35 PM »
Well don't I feel like a horses arse.  :-[
RDJP President
