Author Topic: 35 inch toyo mt's  (Read 3879 times)
Offline newfie
  • newbie and loven it
35 inch toyo mt's
« on: July 09, 2012, 05:18:34 PM »
 hey gang
just picked up a set of 35 , 12.5 x17  toyo mts. Now i have a 2000 tj  on a 4.5 inch lift.
 my question  now is what  offset ( backspacing ) i should get to make sure i dont have rubbing issues at  full turning ???????????????????????????
anyone  got a spare i could through on to try or know a straight answer for me 8)
newfies are everywhere
Re: 35 inch toyo mt's
« Reply #1 on: July 09, 2012, 05:28:14 PM »
I run 1.5" spacers on 35's  with 4.5" back spacing on the rims.  Works well.
Offline newfie
« Reply #2 on: July 09, 2012, 06:28:49 PM »
dont want spacers  just run a rim :o
Offline Jrama
« Reply #3 on: July 09, 2012, 06:33:35 PM »
4.5 - 1.5 = 3.00" bs
Typical jeep rims for a 12.50 are 3.25
« Reply #4 on: July 09, 2012, 07:10:10 PM »
You may also want to invest in re-gearing or a blower. Dem Toyos are HEAVY.
Great tires though.
Offline newfie
« Reply #5 on: July 09, 2012, 08:03:30 PM »
geared to 5.13 with arb's
Offline newfie
« Reply #6 on: July 09, 2012, 08:04:10 PM »
dont know about u guys but i a'nt found a 17 rim with 3.25 bs
Offline Dingleberry
« Reply #7 on: July 09, 2012, 08:11:41 PM »
Maybe Jamal meant to say 3.75" BS because that's what I find is most common at least for 15' rims.
Offline Jrama
« Reply #8 on: July 09, 2012, 08:33:03 PM »
Oops  sorry I had 3.25" in my head for some reason
Little did I know My stock 15x8 have 5.5 BS I added 1.25 spacers giving 4.25 and yes sir my tires rub.
« Last Edit: July 09, 2012, 08:57:55 PM by Jrama »
Offline newfie
« Reply #9 on: July 09, 2012, 10:13:50 PM »
so if you rubbing u dont have the right rims
 thast what i want help with finding the right rims for a 17 inch
Offline Jrama
« Reply #10 on: July 09, 2012, 10:51:18 PM »
You should know I am talking spacers with my stock rims...
I don't have the right spacers the rims are stock so.....yeah?
 I just posted that last little bit to point out that 4.25 does indeed rub. When I bought the spacers I assumed 5" of BS like most other 15x8 factory rims. 5-1.25 = 3.75 right?
My problem is I am thinking in terms of 15" rims...
17" is a funny size to put on a TJ there is not a ton of info or people who actually make a 17" rim with around 3.75 bs. Northridge has those AEV rims with 17" and 3.6" BS
Looking into it more 4.5" Bs on a 17" rim seems to be the norm and should get you through albeit with some touching! Keep in mind the wider the rim the fatter the tire will be and could rub more, 4.5" seems to work well for an 8" wide rim.
Actually frack it don't take my advice....I like to think I know more than I actually do  ;D I'm not having a ton of luck getting a definitive answer either..and I don't want to look into it anymore...thats your job
here's a useful-ish thread
http://www.jeepforum.com/forum/f15/17-wheels-tj-stock-axles-1371940/
« Last Edit: July 09, 2012, 11:38:41 PM by Jrama »
Offline newfie
« Reply #11 on: July 11, 2012, 05:19:29 PM »
hey i did finally find a set of 17 x9x 3.5 bs on 5 x 4.5 bolt pattern that should work
