Author Topic: zj rock sliders  (Read 7395 times)
Offline bradley
zj rock sliders
« on: July 12, 2012, 10:35:09 PM »
After the fathers day run i have realized i need to start making more armor for the zj.
The question is r rock slides bolted onto the frame or r they welded.
Any advice from anyone who has built them b4 would b appreciated
thanks in advance
2002 jeep tj, 7 inch lift with long arm front and triangulated 4 link rear, 37x12.5x15 maxxis creepy crawler tires, custom front and rear bumpers, 12000 winch, G2 dana 44 front with detroit locker, 44 rear with spool, custom rear skins and flares, sye kit
Re: zj rock sliders
« Reply #1 on: July 12, 2012, 10:37:34 PM »
Uh....ZJ = no frame.
Johnny or Fraser or NUXJr can fill you in on sliders for the Sleezy Z.
Offline bradley
Re: zj rock sliders
« Reply #2 on: July 12, 2012, 10:40:43 PM »
ya no kidding!
i am pretty sure u know i mean the shitty uni-body sub frame
Re: zj rock sliders
« Reply #3 on: July 12, 2012, 10:46:31 PM »
Bolted or welded to the unibody, then bolts through the pinch seam below the doors. I'll grab some pics
Offline bradley
Re: zj rock sliders
« Reply #4 on: July 12, 2012, 10:49:44 PM »
thanks
Re: zj rock sliders
« Reply #5 on: July 12, 2012, 11:02:48 PM »
buildin some soon buddy.
next few weeks.  i'll take step by step pics for you.
they will be welded into the frame.  we will be welding 1/8" plate into the 'frame rails' for support and bolted into the pinch seam in the rocker.
what i'm doing to the front is gonna be sick though ;)
Offline bradley
Re: zj rock sliders
« Reply #6 on: July 12, 2012, 11:20:12 PM »
i am not 100 percent sure when i will actually start building them, but i am planning a bit different of a way on building them, the bottom section underneath the doors is pretty rotted out so i wanted to cut most of that out and build the rock sliders into that section, i havent taken a really good look at it yet to c if it will  actually work but thats the plan so far
Re: zj rock sliders
« Reply #7 on: July 12, 2012, 11:47:00 PM »
It will work but it's a major pain in the buttocks. Cutting out the rusted rocker panels and incorporating a slider is a kill two birds with one stone situation. I've helped a poor bastard do this 2 years ago and it was very time consuming . Two XJ guys I know that have done this swear they would never do it again. Totally doable though
Offline bradley
Re: zj rock sliders
« Reply #8 on: July 12, 2012, 11:50:06 PM »
well thats good to hear, i dont need easy i just need doable
Offline NUXJR
Re: zj rock sliders
« Reply #9 on: July 13, 2012, 12:37:37 AM »
I've got the Ironrock sliders on mine if ya wanna check em out ;D
Offline bradley
Re: zj rock sliders
« Reply #10 on: July 13, 2012, 12:41:12 PM »
Sure I wouldent mind takin a look
Offline Pookapotamus
Re: zj rock sliders
« Reply #11 on: July 13, 2012, 01:20:10 PM »
I have done the Genright sliders to 2 of my Xj's by cutting out the rocker panel and welding the sliders up inside. It is not that big of a pain if you have done it before, my first one turned out ok and was functional but did not look great.the second was far easier and looks great. If you have the time and skill I would totally recommend doing it this way. And I will be doing this to a friends Xj When he gets around to fixing his. let me know if you want some pointers, might even have a few pics some where.
Pook
Offline bradley
Re: zj rock sliders
« Reply #12 on: July 13, 2012, 08:31:55 PM »
Pook
thanks, once i get going i will send you a pm if i have any questions
Offline NUXJR
Re: zj rock sliders
« Reply #13 on: July 16, 2012, 08:46:23 AM »
They were on the ZJ at the Father's day run ;)
Offline bradley
Re: zj rock sliders
« Reply #14 on: July 16, 2012, 11:16:35 AM »
Ya I saw them on there they looked awsome, I was more curious to how they were mounted tho
