Author Topic: TJ lift noise's  (Read 1185 times)
Offline bdron
TJ lift noise's
« on: July 28, 2012, 02:30:42 PM »
I put a 2" lift in my tj but didn't put in track bar extentions, I put in 2" coil spring spacers in the rear.  Now I am getting a knock, knock or a bump, bump from the rear drivers side when I go over any little crack in the road. Any suggestions would be appreciated.
Brian
« Last Edit: July 31, 2012, 10:52:17 AM by bdron »
Offline Moezer
Re: TJ lift noise's
« Reply #1 on: August 06, 2012, 10:06:22 PM »
a 2 inch lift wont have any problems...., check your bump stops or check if ur spring is sitting good, also check ur shocks they mitght be shot
Offline GreenMachine
Re: TJ lift noise's
« Reply #2 on: August 10, 2012, 12:57:51 PM »
I put a 2 inch budget lift in, I had to put in a tcase drop in, I had to much angle going into my rear pinion, no one had ever heard of tht on a 2 inch lift, it smooth now, before vibrated constantly, probably not the same thing, but not all 2 inch lifts go in smooth,
Why year of tj?
Offline Moezer
Re: TJ lift noise's
« Reply #3 on: August 11, 2012, 05:49:12 PM »
thats funny green, i just put in my roughcountry 3 inch spring lift and put the tcase drop andi started to vibrate like crazy deathwobble like a mofo i couldnt hold my steering wheel and that i was only going 60 took it out and now every thing is fine
