Author Topic: TJ suspension lean  (Read 2624 times)
Offline Knox
TJ suspension lean
« on: August 16, 2012, 11:11:11 AM »
So anyone have issues with a passenger side lean? Been reading about it one few other sites and due to engine torque the passenger Side springs will sag over time...
So my jeeps sitting an inch down on the right front and rear, what do most people do for this? Just swap spring sides, add/remove spacers? I could do new springs and was thinking about picking up OME coils but they seems to be a bad culprit for this as much as RC is. I'm happy with the amount of lift so I'd like I stay in tw 2.5-3" range suspension wise for my daily driver
2003 TJ
Re: TJ suspension lean
« Reply #1 on: August 16, 2012, 11:55:16 AM »
Have the same thing on mine.   I just turn my head until things are level again...
Offline raf2379
« Reply #2 on: August 16, 2012, 01:49:01 PM »
its not just from torque, the engine is slightly offset to the passanger side as well. ACOS adjustable coil spacers work well, I had them on my  x - J to fix the same issue and I wanted 1.5" more lift.
« Reply #3 on: August 16, 2012, 03:42:38 PM »
I'm fat so it counter ballance the passenger side leaning...
Just get on the Bacon diet and you will not have that issue anymore   ;D
Offline GreenMachine
« Reply #4 on: August 16, 2012, 08:54:53 PM »
I had my Tjs front drivers wheel off the ground yesterday, but that was a combination of speed and the corner, not so much sag on passenger side haha
Offline DOKTORJ
« Reply #5 on: August 20, 2012, 07:14:54 PM »
I've had 2 different lifts on my Jeep and they both had the "lean". It's a Jeep thing. The only thing you can do is ditch the coils/shocks and go big with coil overs.
« Reply #6 on: August 20, 2012, 07:47:19 PM »
You need to put leaf springs on all four corners to get it sit level.
« Reply #7 on: August 20, 2012, 08:55:16 PM »
And this is why our XJs also lean? But more front to back to compensate for the amount of crap we can fit in em ;)
Offline 89cherokee
« Reply #8 on: August 20, 2012, 09:36:19 PM »
This thread is comic gold
