Author Topic: 99 xj rough Idle?  (Read 2071 times)
Offline che
99 xj rough Idle?
« on: September 03, 2012, 08:14:29 PM »
Hello, This is a shot in the dark but I figure I would ask the pro's ;)
I just bought the xj and it has a rough idle. all i know about it is that it last for maybe 30 seconds on every start up. seems like it wants to stall and then will regain itself. if i rev it up then it will go away. I know i'm not giving you much to work with but I'm just getting into it....
Anything will help
2010 wrangler Sahara
2012 mustang 5.0
99 Cherokee xj
Offline BUKI
  • Project Fugly
Re: 99 xj rough Idle?
« Reply #1 on: September 03, 2012, 10:04:50 PM »
Codes?  sounds like IAC.  I would take t body apart and clean it as well as IAC portion put it back together and see if it helps
Offline che
« Reply #2 on: September 04, 2012, 03:45:26 AM »
It's not throwing any codes.... But he could have pulled the light possibly. I'm sorry but what's the IAC?
2012 mustang 5.0
99 Cherokee xj
Offline BUKI
  • Project Fugly
« Reply #3 on: September 04, 2012, 09:03:08 PM »
Idle Air Control.  Its a stepper motor that pushes in and out to let more air in for idle.  (Fast idle)
« Reply #4 on: September 04, 2012, 10:19:37 PM »
Idle Air Control.
X2.
Ended up replacing mine on my 2001 and it solved my issues...
Offline birdo
  • 99 TJ
« Reply #5 on: September 05, 2012, 01:43:27 PM »
Or you could try taking it off the throttle body and cleaning it. Easiest with the throttle body right off. Watch them little Torx screws. They can be tough to remove and easily stripped. Carb cleaner is your friend.
John Bird
Okotoks Alberta
1999 Jeep TJ Sahara
Desert Sand
Some Cheapo Clarion Stereo
Heated Seats, Air-Con, Cruise
230,000 kms
