Author Topic: 4.5 Rough country front end set up.  (Read 2739 times)
Offline Aspirated
« on: September 23, 2012, 09:54:31 AM »
Anyone know a shop  that will set up my front end after my lift? Its a 4.5" with adj track bar.
1998 XJ
2008 KK
Re: 4.5 Rough country front end set up.
« Reply #1 on: September 23, 2012, 10:03:18 AM »
are you control arms adjustable
if so adjust them so your pinion angle is the same as stock
and for your track bar adjust it until your steering wheel is straight
« Reply #2 on: September 23, 2012, 10:43:42 AM »
On rough country ,s website there is a chart to get the length right ob rhe control arms. Instuction manual page ?  Some times you have adjust them from there for your caster angle so your steering returns to center or to adjust your pinion angle so the front drive shaft does not viberate.
Broken axle has an alignment rack and could set you up right.
Offline Aspirated
« Reply #3 on: September 23, 2012, 12:17:20 PM »
the lower control arm in the kit are non adjustable.  :'(
1998 XJ
2008 KK
« Reply #4 on: September 23, 2012, 01:02:50 PM »
ive always had good experiences at Kirks Tire on blackfoot. Fair prices and quality work. If you need a shop to check it out, they would be the first place I call.
Offline Jrama
« Reply #5 on: September 23, 2012, 01:29:27 PM »
Call Broken Axle  they do this kind of work all the time.
« Last Edit: September 23, 2012, 01:31:25 PM by Jrama »
Offline Knox
« Reply #6 on: September 25, 2012, 11:26:12 PM »
wut?
Adjust the track bar until the axle is centered. Use the drag link to straighten your steering wheel when you're done.
http://www.4x4xplor.com/alignment.html
2003 TJ
« Reply #7 on: September 26, 2012, 12:19:27 AM »
wut?
ya thats what i ment .. someone put to much rum in my glass hahaha
man i got to stop drinking so early in the evening
Offline Aspirated
« Reply #8 on: September 26, 2012, 06:48:33 AM »
Had my truck over to Broken Axle. All went well. Front end tight, drives straight. Thanks for the recommendation.
1998 XJ
2008 KK
Offline Knox
« Reply #9 on: September 28, 2012, 08:08:21 PM »
I thought you knew better Jeff :P
Aspirated, glad you got it all looked after.
2003 TJ
