Author Topic: Baja MTZ or Toyo M/T?  (Read 2389 times)
Offline tzettler
« on: October 15, 2012, 07:24:26 AM »
Is there a question?  I tried searching and didn't find much comparison between these two specific tires, so I figured I'd just ask outright... Some simple answers and simple details would be fine... I am thinking of going with the MTZ as it seems to have a more aggressive tread pattern, though I hear the Toyo's last longer... Is this concrete, or merely a hopeful guess? Thanks all... By the way, ill be using them for both light to moderate/heavy off-roading, and a lot as a DD, approx 75km+ per day.
2013 JK Sport, 33x12.5x15 Baja MTZ, Warn M8000 Winch, Flo~Pro MX500 muffler
Offline WK2008
Re: Baja MTZ or Toyo M/T?
« Reply #1 on: October 15, 2012, 07:42:13 AM »
Wow that's a good pair to compare. I ran the MTZs and Toyo's and they are both a great tire. I would lean towards the MTZ for a daily driver as they would be better for snow and ice. The Toyo's would be a great trail tire but I think they are heavier than the MTZ. My pick is MTZ for a better all around tire that will still see some trail use.
Offline WK2008
« Reply #2 on: October 15, 2012, 07:52:49 AM »
Here are the weights for the Toyo's.
35x12.50R17 125Q E/10 - 83lbs
The MTZ's are as follows
LT315/70R17 or 35x12.50R17 121Q D/8 - 68 lbs
Thats an extra 15lbs of rotating mass. I know where my vote woul go if fuel mileage and power are a concern.
Offline tzettler
« Reply #3 on: October 15, 2012, 12:59:40 PM »
Hey man yeah thanks, I'm definitely siding with the MTZs... Just needed a bit of reinforcement in my decision!
Offline WK2008
« Reply #4 on: October 15, 2012, 01:46:47 PM »
Give Drew or Rob a call at Modern and they can set you up. Great guys to deal with.
