Author Topic: Compressing springs  (Read 2877 times)
Offline AstraX
Compressing springs
« on: October 27, 2012, 04:37:17 PM »
So I am making an attempt at installing my spring spacers and shocks.  Having a hell of a time getting the springs back in now and I have let the axle drop as much as I can (brake lines are limiting).
Any tips?  At the rate I'm going I won't be done until the new year.
Thanks in advance.
Offline binare
Re: Re: Compressing springs
« Reply #1 on: October 27, 2012, 04:43:26 PM »
Creative use of a crowbar and lots of grunting coupled with a slight pucker factor. Or you can be smart and rent a spring compressor, I personally prefer the crowbar.
Offline dubbleJs
« Reply #2 on: October 27, 2012, 04:44:12 PM »
You can rent spring compressors from auto value for free (with a returned deposit) or just but a pair of  compressors at PA for about $40. Just make sure they are clamped onto the coil straight and proper... They are under a lot of pressure once you crank them tight!
Offline AstraX
« Reply #3 on: October 27, 2012, 06:36:56 PM »
Ratchet straps ftw..1 down 3 to go :-\
« Last Edit: October 27, 2012, 08:19:23 PM by AstraX »
Offline GreenMachine
« Reply #4 on: October 27, 2012, 08:28:54 PM »
Have you ever seen a spring come loose under full compression? I would rent a "strut compressor" the two separate piece kind, locks onto springs, it's a little more safe.
« Reply #5 on: October 27, 2012, 08:31:41 PM »
Unbolt the calliper from the axle and let it drop more.
Offline LEMON-AID JAY
  • Bad a$$ zj owner
« Reply #6 on: October 27, 2012, 08:47:48 PM »
Yup and the trac bar if you have not done so yet.
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
« Reply #7 on: October 27, 2012, 09:40:35 PM »
Dan, i have the spring compressors you need. if you can find your way down here  you can borrow them.
please don't use ratchet straps.......
they are the ones you can buy at PA............
Offline .:.Dingman.:.
« Reply #8 on: October 27, 2012, 09:43:27 PM »
Strut compressor and coil spring compressors are two different animals. I have a set of coil spring compressors if you want to borrow them I'm in the northeast.
Dingman
Offline heep-a-lop
  • EMF WHORE
« Reply #9 on: October 27, 2012, 10:02:24 PM »
once u seen a flying spring u will only use the correct tools that crap flys and can frickin' kill..... no word of a lie seen one hit a guy in the chest biggest blackest bruise i have ever seen...
please be carefull...  flying metal is not cool...
Offline AstraX
« Reply #10 on: October 28, 2012, 01:27:23 AM »
I will clarify... :D
I did not use ratchet straps to compress the spring, I used it to stabalize it front to rear while I worked it over the lip with a pry bar, they were there more as a fail safe in case the spring did try and pop out.  I have heard the warnings about compressing a spring incorrectly so I was trying to avoid that route.
I thought of that, but I'm a rookie at this stuff and was a little worried about messing around with my brakes.
Thanks for all the concerns and offer for the tools.
« Reply #11 on: October 28, 2012, 09:06:27 AM »
Just listen to clay and jay. You do a 6 inch lift spring without compressing if you take the right stuff apart.
Disco shocks, trackbar, sway bar, and brake lines. Insert springs with no fight. Bolt everything back together.
Apparently it's good that you brought it up since lots of guys here are still squishing springs.
« Reply #12 on: October 28, 2012, 09:47:51 AM »
Thats why its good to ask. Unbolting the caliper and laying to the side is super easy and you don't lose any fluid.
« Reply #13 on: October 28, 2012, 08:35:26 PM »
You can use those ratchet straps to hold up the caliper, they are pretty heavy so just letting them hang from the stock rubber hoses (usually half rotten) isn't the best idea. I've done it (let them hang) but I'm also ok with changing brake lines and bleeding the system after.
Offline dubbleJs
« Reply #14 on: October 28, 2012, 09:14:36 PM »
IMO compressing the spring with the proper tool is a much better way to do it and so much less work than unbolting everything holding that diff in place...?
