Author Topic: Rebuild of a drive shaft  (Read 1881 times)
Offline JeepNaked
« on: December 12, 2012, 01:45:06 PM »
Looking for a shop that could repair my front drive shaft. The splines are screwed up.
Sent from my iPad using Tapatalk HD
Offline AV.NINE
Re: Rebuild of a drive shaft
« Reply #3 on: December 12, 2012, 06:48:56 PM »
Cory and Jason at commercial have done a ton of work for me lately.
Cory competed in top truck challenge in 2002. Been searching for videos but haven't found any yet.
« Reply #4 on: December 12, 2012, 09:50:37 PM »
sounds like your shaft is fawked and you might need a new one.........i've heard (cannot confirm) that isn't a fixable issue
Offline rws
  • Stump Grinder
« Reply #5 on: December 17, 2012, 09:40:36 PM »
Danco (Commercial Truck) just built a couple of drive shafts for my Atlas install.  Price was good and quality also looks good.
« Reply #6 on: December 18, 2012, 05:02:19 PM »
Another Kudos for Commercial Truck. I had a driveshaft built by the "other guys" earlier this year and even after having them balance  it a second time, I was still fighting vibes. I finally had Commercial balance it today (it was out by 19 grams).
I installed it and promptly ran the heep up to 150kmh and it's smooth like butta.
Offline Uboatcmdr
« Reply #7 on: December 19, 2012, 01:10:21 AM »
I have always gone to pats driveline on blackfoot just south of glenmore for any driveshaft work.
I had bad splines on my front driveshaft and the quote was around 600 dollars to install a new slip joint, new u joints and balance.
In the end i got a new driveshaft from Tom Woods for around 250 shipped. Plus you get a sick "My shafts a Woody" sticker !
This included a longer travel stronger slip joint, their house brand "Gold seal" U-joints and thick wall DOM tubing.
www.4xshaft.com
As my Highschool mechanics teacher would say "Never cheap out on Joints! And no these arent the kind you pass around between your friends!"
Offline Jrama
« Reply #8 on: December 22, 2012, 02:34:40 PM »
I have had great experiences at Pat's but due to reccomendations on this board I decided to give Commercial trucking a try.
It needs a new CV, Splines are shot....Joints are getting replaced with Spicer sealed joints.... only good parts were the H block and tubing. Not only did they diagnose the problem (Pat's did not) but their prices are significantly better as well. I'm north of $300 for the work being done, Uboatcmdr's price reflects the ball park Pat's would cost for just the splines. Customer service thus far seems to be fantastic as well.
Any work you needs done...you know where to go
« Last Edit: December 22, 2012, 05:48:23 PM by Jrama »
Offline rws
  • Stump Grinder
« Reply #9 on: December 23, 2012, 04:47:04 PM »
Picked up a couple of pinion seals at Pat's and just about feinted at the price, $35/each.
After 20+ years of business with these guys I'll be price shopping before any more purchases.
