Author Topic: Hydralic Floor Jack  (Read 2259 times)
Offline rws
  • Stump Grinder
Hydralic Floor Jack
« on: December 17, 2012, 08:07:30 PM »
Any one know where I can get a hydraulic floor jack fixed?  After having 20 cheap ones I finally buy a good one from NAPA ($400) and it did not last as long as the cheap ones.   There used to be a shop in Calgary that repaired them but....   The jack does not hold pressure and there is no rebuild kit available.
Offline dac
Re: Hydralic Floor Jack
« Reply #1 on: December 17, 2012, 08:15:07 PM »
what's the brand and have you gone to their web-page to find a local service rep or parts list?
Offline rws
  • Stump Grinder
« Reply #2 on: December 17, 2012, 09:36:03 PM »
Yup, done that. The brand is NAPA and it was manufactured by NAPA LIFTING EQUIPMENT (read China).  There is no rebuild kit for it so what I need is a reputable hydraulic shop that deals with these tiny jobs as I don't want to spend a thousand hours on a ghetto fix that may or may not work.
Offline .:.Dingman.:.
« Reply #3 on: December 17, 2012, 10:00:08 PM »
ABS Hydraulic Repair gets my vote they do all our rams at the shop.
Dingman
Offline Crunch
« Reply #4 on: December 19, 2012, 12:11:26 PM »
Red Dragon Hydralics. very good work. Im in the heavy equipment industry and have used them alot
Ive used others and have not been very happy at all.
Offline slimbeam
« Reply #5 on: December 19, 2012, 03:30:50 PM »
did you try and take the pump part apart you may just need to replace an "O" ring
Offline Gearhead
« Reply #6 on: December 20, 2012, 08:18:42 AM »
What's it not doing  ?
They are not  at all complicated  , as already mentioned  it could be an easy tweak that may get it going again.  I bought  a good sized asian floor jack at least ten years ago , it has had issues that I was able to overcome  without difficulty.
On a similar topic ,  I have a very old hydraulic motorcycle lift bench , I think it was made overseas  , maybe not asia , possibly italy  . It's old and has been used commercially ,  About seven years ago I decided to restore it , repaint , rebuild the hydraulics , freshen it up , it leaked oil pretty bad . There are similar bike lifts still available , the units sold at pricess auto are an asian copy of the  lift I have .  I ordered a seal / overhaul kit to rebuild the hydraulics from one of my suppliers , after all it looked the same ???  .   I disassembled the entire lift , repainted all the pieces and started to rebuild the ram & foot pump mechanism only to find  that the main seal for the piston wasn't even close to what was needed !  My solution was to make a new piston , changing the design so that I could use the seal that was in the rebuild  kit , it worked well and is still in use with  no leaks .
Try fixing it yourself  .
I've seen new hydraulic units that were low on oil right out of the box.
« Last Edit: December 20, 2012, 08:32:09 AM by Gearhead »
